Whirlpool Duet Sport HT WFW8400TE Washer Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F-22 is my error code. What is that? - Whirlpool Duet Sport HT WFW8400TE Washer
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Nov 25, 2010
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628885
Points
28464
F22 DOOR LOCK ERROR
After 6 failed attempts to lock the door.
Possible Causes/Procedure
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
What does ERROR CODE e05 means in "KONKA" WASH MACHINE
GOOGLES ANSWER TO QUESTION BELOW
https://www.google.com/search?q=What+does+ERROR+CODE+e05+means+in+%22KONKA%22+WASH+MACHINE&oq=What+does+ERROR+CODE+e05+means+in+%22KONKA%22+WASH+MACHINE&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
2helpful
I am getting diagnostic code 22
Error Code: 22
Description: Engine Coolant Temperature circuit malfunction.
Possible Causes:
- Wiring.
- Coolant Temperature sensor defective.
- ECM.
2answers
Error code 22
"Error 22" on a Pioneer usually means an unsupported CD format. The disc you are trying to play is not supported or is very badly scratched so the player cannot determine the format.
Error 22
does this help?
http://pcsupport.about.com/od/errorc/a/code-22-error.htm
1helpful
Error e42 22
Apr 24, 2011 ... E40 20 = Other hardware error. E42 22 = Scanner error. How to reset CANON WASTE INK COUNTER MP160/MP145 Before you reset the ... canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html
have just checked this site and I am sure it will help you
I have SandDisk S3 UCL Mode USB Device which is not detecting right now. One week back its working fine. In computer management i found device has in diabled mode. when i try to make it enable its again...
How to Fix a Code 22 Error
  1. Enable the device. Since the most common reason you'll see a Code 22 error in Device Manager is because the device has been manually disabled, try manually enabling it.
    Most of the time this will fix a Code 22 issue. Don't worry if it doesn't, however. All that means is that the Code 22 you're seeing was caused by something a bit less common.
  1. Restart your computer if you haven't already.
    There's always the chance that the error Code 22 you're seeing on a device was caused by a temporary problem with the hardware. If so, a restart of your computer might be all you need to fix the Code 22 error.
  2. Did you install a device or make a change in Device Manager just before the Code 22 error appeared? If so, it's highly likely that the change you made caused the Code 22 error.
    Undo the change if you can, restart your PC, and then check again for the Code 22 error.
    Depending on the changes you made, some solutions might include:
  1. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is one possible solution to a Code 22 error.
    Important: If a USB device is generating the Code 22 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
  2. Update the drivers for the device. It's also possible that installing the latest drivers for the device could correct the Code 22 error.
    If updating the drivers does remove the Code 22 error, it means that the stored Windows drivers you reinstalled in the previous step were either damaged or were the wrong drivers.
  3. Clear CMOS. If Windows had to disable the device, generating the Code 22 error due to a lack of system resources, clearing CMOS might fix the problem.
  4. Update BIOS. Another possibility is that a newer BIOS version could better pass system resource handling to Windows, correcting the Code 22 error.
  1. Move the device to a different expansion slot on the motherboard, assuming of course that the piece of hardware with the Code 22 error is an expansion card of some kind.
    If the Code 22 error is due to a lack of system resources available for the card, moving it to a different slot on the motherboard could clear up the problem. This isn't as common a situation with newer hardware and Windows versions but it is possible and is an easy troubleshooting step to try.
  2. Replace the hardware. A problem with the device itself might be the root cause of the Code 22 error, in which case replacing the hardware is the next logical step.
    While not likely, another possibility is that the device is incompatible with your version of Windows. You can always check the Windows HCL to be sure.
    Note: If you're positive that the hardware is working properly and is properly configured then you might consider a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either before you replace the hardware, but you may have to give them a try if you're out of other options.
Please let me know if you've fixed a Code 22 error in a way I haven't mentioned above. I'd like to keep this page as accurate as possible.
What Does the Code 22 Error Apply to?
The Code 22 error could apply to any hardware device managed by Device Manager.
Any of Microsoft's operating systems could experience a Code 22 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 22 Issues in Device Manager?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more.
Be sure to let me know that the exact error you're receiving is the Code 22 error in Device Manager. Also, please let us know what steps you've already taken to try to fix the problem.
Show Full Article
4helpful
2answers
Error code E01-22
The error E01-22 means polygon motor synchronization error.
The possible causes for the error is problem with ;
- engine pcb
- laser unit
- lvps
- sc pcb
You can try to reseat the connectors, else you may need to replace the board.
Code (22)
Dear Customer,
There are some vital informations and solutions regarding Code (22) error..
Code 22
The text displayed for this error code differs depending on the circumstances.
  • If this device is disabled because you disabled it using Device Manager, the following text is displayed: This device is disabled. (Code 22)
    Click Enable Device to enable this device. Solution button: Enable Device
  • If the device is not started, the following text is displayed: This device is not started. (Code 22)
    Click Start Device to start this device.
    Solution button: Start Device
  • If the device is disabled by a driver or program, the following text is displayed: This device is disabled. (Code 22)
    You can't enable this device because it has been disabled by a Windows driver. Solution button: None
This code means that the device is either disabled or has not started.
To resolve this error code, follow the recommended solution. For the third case, try removing the device in Device Manager, then redetecting it using the Add New Hardware wizard. If the problem persists, try a clean boot to rule out software interference. If the error persists, contact the hardware manufacturer.
Please Rate this Solution.. Thank You..
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
