Uniden BC72XLT Handheld Scanner Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a UBC72XLT scanner which I sometimes use with a external roof mounted antenna. Recently while connecting this antenna to the scanner there was a static discharge. The performance is now way down so obviously some damage was caused. Question: Is there anywhere I can send the scanner to be checked out & possibly repaired ?
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Nov 25, 2010
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
934183
Points
7369
You can contact the Uniden customer service department via email by following this link:
http://www.uniden.com/repair/info.cfm
But the cost of repair will likely exceed the value of your scanner. I routinely see used and refurbished BC72XLT scanners for sale on eBay in the $50 range.
Bill B.
Listening in since the 60's
I cannot get any tv stations from service search
i'm guessing you hooked up an inside rabbit-ear style antennae?
move it around
then do an auto scan again
it all varies upon your location of that antenna
sometimes an amplified antenna helps a bit as well to draw in those digital signals to your tv tuner card that is built-in on that flat screen TV
other times, in other areas, you'll probably have to get an external antenna mounted to the roof of your house or a tall metal pole that can be moved towards those signals
2answers
I have 2 cobras 29 radio always worked good till recently. Have a rk56 mic I can hear but can't talk. Mic keys up but they hear nothing bought a new 29 chrome digital read out and a new mic just a wood...
fiberglass,no ground plane. Did you use the meters on the radios to match your antennas or a seperate external antenna.you might have to run your own coax and hook up a mirror mount bracket and put your favorite antennas on them then match them and ground them to the chassis use common sense to show you what to do next and you should be getting out great. Sometimes people change the antennas on those trucks with built in antennas and don't realize that the coax has just fallen out of site into the body somewhere. thats why I said install your own.
2answers
Dlink external antenna configuration
Hi .In my Experience if you Change the Antenna Must be equal Both are Antenna Like 12 dbi Otherwise you are facing the Slow Issue.
must be same DBI Antenna (on my Experience 2700 AP I Face same issue ) when i change the Antenna both are Equal It s Fine working Thanks
When explaining that an antenna needs to be 'gounded', does this mean that the bracket the antenna is attatched to needs to be actually hard wired to the vehicle frame or when using a magnetic mount...
Hi, my name is John. Welcome to FixYa. Yes, That is not sufficient enough for your antenna. Need any further information let me know. Thanks for choosing FixYa...John
I have a unidenbc72xlt scanner--I live in a rural area and reception is terrible. when i get to city(about 25 miles away) it works good but at home is terrible--any solutions
Your ONLY solution is an external antenna. The best scanner is only as good as the antenna that feeds it. A discone would be the best, but a less-costly vertical would probably do a good job for you. The least costly, and least effective solution would be an indoor antenna - the ones enclosed in PVC pipe do a fair job. If you can't mount the antenna on your roof, a balcony or an attic will usually work fine. As a last resort, you can always set up a vertical inside a closet. eBay is a good source for scanner antennas, and you might also try www.ScannerMaster.com.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
2helpful
3answers
How do i install a cb radio on a pick up truck
You will need a CB radio antenna, The CB radio and mounting hardware as well as the power wire.
Choose a place to mount the radio. Mount it. Run the power wires from the radio to the fuse box. Put red wire in with the fuse that is hooked to switched 12 volt. Ground the black wire to any metal of the vehicle.
Next find a place to mount the antenna. If you use a mag mount, the roof of the cab is a best bet. Run the wire into the vehicle, it can go through the door, just make sure its not going to get pinched.
Hook the coax from the antenna to the radio
Now you have to tune the antenna. this is important because if you don't you you will blow the transmit final transistor out in the radio.
This link will take you to an article that will explain how to tune your antenna.
Where can i find an external antenna
are you tallking about old school aluminum roof mount antenna,radio shack has a nice portible version of the old roof mount models,benn a couple years scince i bought mine,you might have to search their catalog or web site if you dont see one at the store near you
I have a 03 f 250 superduty v 10 i would like to know how to know where to drill hole in roof and how to run coax wire to cb
all vehicles normally have spot at the dome lights. to put cb/ham/commercial antennas. but some ford trucks have a center rib on the roof which sometimes would have to off-center an antenna. on newer trucks. I would use the ham NMO mount that has the 3/8" hole (not3/4") and use a wilson 1000-5000. or tram base load antenna.. depending on power wattage needed. we normally carry the 3/8" mounts they have coax and pl259 connector on them. look us up. lowest prices guaranteed.
1helpful
Uniden UBC72XLT scanner problem.
The cheapest solution would be to directly program the frequencies that are available in your area, usually this is public information with the exception of high security channels, you can call each location and ask them what frequency they broadcast
How do I see the rest of this solution? Garmin Nuvi 660 GPS Receiver Problem: Garmin Nuvi GPS won't acquire satellites Solution by: wingflinger (1 solutions) There is a known hardware bug in the...
you should see it now
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Dec 12, 2008 • Garmin GPS
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
