Unlike most vacuums, this one the screws are on the top of your base. There are two screws one on each side. When looking at the front of the vacuum right side screw is located above the s in 12amps and on the left side screw is located above the p in pet. Now keep in mind it's not directly above the letters look about 2 inches up. Unscrew them, take cover off. Once you have done that pull up on the brush rod. Maybe tough if ur vacuum has a lot of built up dirt. Next put belt on metal prong then put on brush rod. Place rod back in its spot, gonna need little bit of muscle. Then put top back on and replace screws. Plug in flip bottom just to make sure brush is spinning. If u have followed steps this should work. I hope this helped took me forever to find the screws because I have always had vacuum with them on the bottom and internet was no help to me. Good luck
Thanks for the info. Those screws were hiding in plain site! :)
Thanks for the info, Madopmom. Those screws were hiding in plain site!! :)
Thanks so much for the info, was driving myself crazy trying to locate the those hidden screws :O)
I agree with Perry. I just didn't see them. Thanks
Thanks for the info
I appreciate you taking the time to put this information on her. Thank you so very much.
Absolutely appreciate this
They are different, i can not tell you the details one by one.
