GPS Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Garmin thinks I'm in Vancouver, WA not Vancouver, BC. Have changed the country, but it doesn't recognize Vancouver as a city?
perdue40
Level 3:
  • Garmin Master 589 Answers
  • Posted on Nov 25, 2010
perdue40
Garmin Master
Level 3:
Answers
589
Questions
0
Helped
122124
Points
1317
Where to......address.....change state / province on bottom.......type BC
then spell city vancouver
2answers
How do I find a postal code number
Just Google the city
Mar 02, 2015 • GPS
1helpful
I NEED INFO FOR THE SUNPAK CL-3 NICD BATTERY CLUSTER FOR THE 622 SERIES:: HOW LONG DOES IT TAKE TO CHARGE: ARE THE BATTERIES REPLACABLE WITHOUT USING A TECHNICIAN:: HOW MANY FLASHES PER CHARGE:: AND
With a little care and some help from a knowledgeable battery supplier..., this can be done by an end-user.
-I am based in Vancouver B.C. and I deal with a company by the name of Polar Battery..., I did a google search for battery cell supplier in Vancouver BC and Polar Battery came up!!!
Note: try the using your particular city / region
-Polar was able to provide me with information as to various battery cel qualities and their prices.
Note: If your existing battery & charger is designed to use Ni-Cad..., stay with them..., likewise Ni-Mh or Li-Ion. This is because each style battery requires its own specific charging parameters. If you change the cells but not the charger..., you could cause yourself some real issues.
Hope this helps..., Peter
1helpful
My garmin doesn't recognize an address
If you are having problems finding a particular address, try some of following tips. In some cases the address may be listed as being in a different city other than the one that was chosen. When the unit asks for the City Name, try choosing Search All Cities. If the address is listed under a different City Name, doing this will allow the unit to find the address. Also, when entering a street name, it is important that you leave off any direction or label. For example, if the address was 2536 SW Melrose Place, you would enter 2536 for the house number and only Melrose for the street name. Using the house number and city/state, the unit will fill in the direction (SW) and label (Place).
If you are still unable to find the address, the mapping may not have the address available yet. Please report this to our Cartography department using the Error Report Form which can be found at the following link:
http://www8.garmin.com/cartography/mapSource/errorForm.jsp
Garmin 510 with City Navigator wont find Paris
change the country to france in the where to > address menu
I live in the city of Vancouver WA. It sometimes takes 5 minutes or more to locate a satelite. I have owned a Garmin-Nuvi 205 before and it always located a satelite immediatley. In fact, when I first...
Please be sure the Operating system is up to date.
Click HERE to download Garmin's WebUpdater.
Once installed - every time you connect your device to the PC, it will make sure it has the latest software for communicating with the satellites.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Need an excel formula.
The crude solution is:
=IF(Sheet3!I2="WA",IF(Sheet3!H2="Vancouver","X",IF(Sheet3!H2="Camas","X",IF(Sheet3!H2="Ridgefield","X",IF(Sheet3!H2="Washougal","X",IF(Sheet3!H2="Stevenson","X",IF(Sheet3!H2="Hockinson","X","?City?")))))),"?State?")
Where ?City? appears when the city referenced in H2 is not part of the lookup
and ?State? appears when something other than WA appears in I2.
But there is probably a better way to do this using an array of valid values like the one below:
AL NY TX WA Birmingham Albany Abilene Camas Huntsville Buffalo Galvaston Hockinson Russell New York Houston Ridgefield Stevenson Vancouver Washougal
In the scenario you could stuff the array in another worksheet and use the HLookup function to find the "Sheet3!I2" value in the first row of this array to determine which column to look in, then VLookup "Sheet3!H2" in the column of that array to see if the city referenced exists. Of course this is a much more complex formula, but it would be easily extendible without changing the formula every time.
For mor info, see "Lookup and Reference Functions" in the Excel Help.
1helpful
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
