Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
SOURCE: WHIRLPOOL MODEL LXR9445JQ0 WASHER. UPPER
You need to replace the agitator dogs. Yes...there is such a thing. These are four small plastic pieces under the agitator cap that grip the upper agitator, preventing it from back spinning under a load. Searspartdirect.com has an excellent illustration of how your agitator is assembled. Just type in your model number and look under the "Agitator, Basket and Tub" heading. The dogs are listed as item 10 (part #80040). For a bit more you can order the entire upper cam replacment kit (which includes the dogs) as item 9 (285811). For instructions on how to replace, just follow this link:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is an expensive and very simple repair. If you require addtional assistance, let me know. I hope this helps you.
SOURCE: Whirlpool LSB6300PW2 Won't Agitate or Spin
if you lift andclose the lid do you hear "clicking" noise??? i bet not. simple repair, lift the lid and with a hollow shafted screwdriver(1/4in nutdriver or similliar hollow shaft implement)you fell with your hand the bottom half of the left side lid hinge. as you open and close the lid you can fell the opposing end of hinge under the top no need to dissasemble you can fell it right there. when you find it simply slip the hollow ended shaft over the hinge and apply pressure towardds the rear of unit.While doing this the top will want to close( your pushing against the hinge).. after appling slight pressure youll bend it slightly, enough to activet the lid switch mounted to the rear of the main lid assy.
SOURCE: washer wont agitate. fills, then a faint hum. it
If it stops filling when it is full, doubt if water level switch. Take clear hose off of side of tub and blow into it, if you hear a clicking noise, it is not the water switch. The capacitor can be checked by placing a test cord on both terminals and applying 110 volts for a second to it. Then using screwdriver, short across the two terminals, if it sparks, it is okay. (be careful to hold the screwdriver handle, it packs a pretty good punch). If that those check out, remove the motor and the rubber coupling. Spin the coupling on the transmission with a large socket both ways. One way should make it spin and the other should make it agitate. If it does not agitate doing this, it is the transmission. If it checks out, then probably in the timer. Good luck
SOURCE: does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
SOURCE: Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
