Everything was working okay before installing a new battery. Function button will not cycle to Aux to play ipod. Manual seemed to indicate we needed to associate ipod with Aux1 again. Tried to start with "initial" on display to be sure we were in "initial setting" mode, but powering off and on with Source knob does not display "inital". Any help would be appreciated.
Thanks to missmis44 i have the answer-----To change your intial settings turn off the stereo, then hold down source butten until clock starts flashing then press the function button which will allow you to turn on aux settings.
mine works just as before
This is easy, Press in and hold the function button and the volume dial,.. after the function menu comes up press function again to get to Aux off.. press up to get it to Aux 1 and then press in the volume dial again and youre set!
Yeah Mine worked fine until my battery in my car went out and now the aux 1 input does not work. I looked to make sure everything was plugged in properly and everything is as it was before it stopped working.
anyone have an update for this yet? i have the same problem.
same problem
