SOURCE: what is the default IP address?\r\nCan its IP be
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
SOURCE: inherited 2 switches 3com 4228g (3c17403) password problem
I haven't worked with these switches but generally settings such as ip address and factory defaults can be set through the Console Interface (CLI). You will need a null-modem cable to access this and a terminal client (Windows Hyperterminal works).
Hope that helps
SOURCE: How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is 192.168.2.10 and the subnet mask is 255.255.255.0"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
AFO
SOURCE: ho to reset dlink3226 switch
Have you got a manual for the D-Link switch?
You may find the info in the manual, if you have lost the manual you can download a manual from this WEB site - Use this link :-
http://safemanuals.com/annexe_Reference%20Guide_D-LINK_DES-3226-_E.htm
