Clean under the needle plate. get it serviced once a year if you sew a lot.
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
if the bobbin is top loading they will flop around some when the start getting close to empty
if it's a bottom loading bobbin & case then it's not inserted correctly
