HP Pavilion F1703 17" LCD Monitor Logo
Posted on Jun 22, 2008
Montior my monitor will not turn on the blue light keeps flashing on and off the monitor is only a year old
Anonymous
Level 1:
  • Contributor 37 Answers
  • Posted on Aug 26, 2008
Anonymous
Contributor
Level 1:
Answers
37
Questions
Helped
8338
Points
53
Sounds like another Power supply/ inverter board problem. If you know electronics you'll have to tear it apart and repair it. I hope it's still under warranty. Hope this helps.
LG W1934S turn on, power led shows blue light, but no display
so working on super old 2007 PC monitors. and no PC connected."? it is NOT ANY LED BACK LAMP monitor here.
came new with XP PC's.
the monitos all good to sleep mode if no PC vidoeo connected.
in the usa, even by law, (energy star)
how ever lacking a PC, the screen will show "no signal entering sleep mode"
VGA monitor.
LED = blue on, amber sleep, LED out, oFF.
NO 1080P mode allowed, (so common now) <<<< big clue here.
set the PC to 1024 x 768 (to test ) 60Hz.
using a flash light (torch) tool,.
turn on Monitor, see blue LED
point flash light to screen, see data, now, on sceen in the beam
now you now CCFL backlamps are dead. as most are this old.
Display Modes (Resolution)
640 x 350
720 x 400
640 x 480
800 x 600
832 x 624
1024 x 768
1152 x 870
1152 x 900
1280 x 1024
1440 x 900
proof BELOW. A FREE MANUAL TOO.
page 47, see 4, CCFL jacks and HV supplies here 600VDC
free service manual with full schematics and BOM
https://elektrotanya.com/lg_w1934s_flatron.pdf/download.html
in my shop I have VGA signal generator to maKE WORK EASY.
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Montior screen is half shaded and half bright
Do this to check if your monitor is in working state or not...!
Step 1:- Turn on your computer.
Step 2:- Unplug the Video Cable of your monitor which is connected with the computer.
( Video cable:- Cable going from the back of your monitor to the back of your tower. It has a plug with two screws on the plug ends, which you can unscrew to unplug it. Thats how it looks like. Some times it is in grey in color some times in blue.)
Step 3:- Now check on your monitor. If the display says " No Input Signal " :- your monitor is fine. Some thing wrong with the computer graphics.
If there is not display and the monitor light is blinking or solid the monitor has gone bad.
( Note :- Remember when you unplug the video cable do not unplug the power cable of the monitor. )
Let me know if it helps.
Philips Brilliance 200 W 6 Flat Screen Monitor blacks out
sounds like the monitor is burning out or color is out of alignment could be result of burning out and no it's not worth repairing it. had one guy repair a montior a while back, could be looking at easy 200 to 400 bucks repair. not worth it. much cheaper to buy.
Monitor will not turn on blue light flashing bottom right hand of monitor
I'm having the same problem. Had the monitor for almost 2 years and everything was working fine until this week. The blue light would blink, then after an unpredictable period of time, the monitor would turn on. Seems like it needs to warm up or something. I suspect it has something to do with the capacitors not charging inside. Somewhat disappointed with Sceptre. I suppose I should be thankful that I got 2 years out of it.
1helpful
Xerox computer monitor light keeps flashing
try swapping a known good monitor to make sure its the monitor?
http://www.aa1consulting.com
2helpful
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
1helpful
Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Monitor turns it self off
exact same thing has happened to me. I have been told it's some part which often burns out on lcd's which can be replaced easily...
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
