If you have not replaced the lamp or if it has had 3000 to 5000 hours of use, the lamp could be worn and needs to be replace. The access door is located in the back, right of center. When you remove the lamp door, you will need to loosen the retaining screws that hold it in place. the part number is printed on the lamp cage. Mitsubishi parts department phone number is 1800-553-7278.
I hope this helps,
Skyassoc
