Expert
- Posted on Nov 24, 2010
Re: I was able to clear the locked door message, and get...
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
- With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
- Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
- While you hold the door jamb switch in this position, complete the following steps.
- Press the Clean pad, wait 10 seconds.
- When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
- Wait 10 seconds for the display to clear.
- The door should unlock and there should not be a need for service.
Manual Switch
- Press the Clean pad.
- Close the door.
- Slide the latch to lock the door.
- Hit the cancel button immediately.
- Unlock the door.
Motorized Switch
Manual Switch
- Close the door.
- Unlock the door.
