The buttons on my radio stopped working. The radio and cd player still work, however, when i put in a cd and press the skip button to go to another track it wont work. When I press FM to switch over to radio, it wont work. When I take the cd out and it goes back to radio, I cannot press the numbers with the preset channels I like, so i have to use the tune knob. The equalizer button doesn't work either and neither does the aux button.
I thought maybe a fuse went out, so i went and bought a 10A fuse that was for audio and put the new one in. Buttons still don't work. What should I do?
Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level. Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
Reset the radio by pressing a sharp object (pin, pen, etc.) into the small reset hole on or behind the face. If it doesn't have one, disconnect the negative cable from the battery for two minutes and reconnect. If you still have this problem, the radio is bad.
to start a turntable press Start button and put an arm with a needle across record, if there is no start button, just put arm across record - it should auto-start; to play cd put it in and press play (play button shoud be near the cd slot, together with stop, skip and others)
Hey there...All you have to do is press the CD MODE button while you press the on/off button and it will fix it. This happened to me as well and I thought that I was going crazy...I changed the 9 volt battery but finally got it to work.
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Make sure the cd is snapped into place, and the speakers are plugged in to the correct jacks (right speaker, left speaker specific). Turn the unit on and press the function button (far left) until you see "CD" - the other functions are "RADIO" and "AUX" - you should be able to adjust volume, track numbers, etc. If that doesn't work, you might have a lemon --- 90 day warranty, so be sure to get it back!
