Motorola Mobility HT820 Bluetooth Stereo Headphones Headset GIFT Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows 7 can't find driver for my HT820 headset. using a PC850 usb dongle and have installed the windcomm drivers.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1353
Points
Install Service Pack 1. Up until this was released a couple days ago, I was never able to get my HT820 to work with my Dell XPS with internal Bluetooth. After SP1, it worked.
August Brown
Level 3:
Genius:
  • Motorola Mob... Master 1,652 Answers
  • Posted on Apr 26, 2022
August Brown
Level 3:
Genius:
Answers
1652
Questions
0
Helped
352360
Points
5096
Normally, desktop doesn't come with Bluetooth module, and if you want to connect your Bluetooth earbuds to desktop computer, you need to buy a Bluetooth module. If you have a laptop, then you can just go to the control center and switch on the Bluetooth. The last chance might be the broken earbuds. If your the Bluetooth module of your earbuds is damaged, you need to change to a new pair. Here I found a post for help: 10 Best Wireless Earbuds Review
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Motorola Mob... Master 1,001 Answers
  • Posted on Jan 10, 2017
wwlvictoria
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603883
Points
6027
Which artlink is compatible window7, aurora 430 and embroidery unit.Artlink6 is working but doesn't allow me to write to machine.Editor lite v4 doesn't pick up dongle.Nothing wrong with USBports
This sounds more like a driver issue than a software problem. The ArtLink 6 software CD that came with the Aurora 430 had drivers for XP and Windows Vista. However, these drivers may have only been for the 32-bit OS. Windows 7 is the first version of the OS to have had a large number of 64-bit installations.
The latest drivers for the Aurora 430 is available here: https://berninaofamerica.zendesk.com/hc/en-us/articles/200183069-Aurora-Driver-Windows-Vista-7-and-8- . You will need to install two drivers; follow the directions on the site. Make sure that the USB cable is good and that you aren't using a USB hub.
If you have installed the drivers and the ArtLink 6 software still isn't working, ArtLink 7 is fully compatible with Windows 7 and the Aurora sewing machines. The only download site for this software that I've found is https://www.bernina.com/en-CA/Products-CA/BERNINA-products/Software-Designs/BERNINA-Embroidery-software/Advanced-Embroidery-Software/ArtLink-Seven . ArtLink 8 is also Windows 7 compatible. However, I haven't found any documentation on the supported sewing machines.
The driver issue also applies to the dongle. Try this site: https://www.bernina.com/he-IL/Support-IL/Software-he/Embroidery-Software/Dongle-Driver . However, since you have the Editor Lite v4, this dongle may not be supported under Windows 7. The dongle driver is not updated regularly. For some information about the software limitations, see https://www.bernina.com/he-IL/Support-IL/FAQ-he/Software-he/Can-I-update-my-BERNINA-embroidery-software-Editor .
I hope this helps.
(There is a patch for the v5 software to run properly under Windows 7. There isn't one for the Editor Lite v4 to the best of my knowledge.)
2answers
I have bluetooth headset MM100 but Windows 7 cannot locate drivers for it.
This is a strange question I will explain.
The MM100 is working according the A2DP (bluetooth) protocol.
So windows 7 can not find your sennheiser drivers because there are none.
Windows 7 needs the driver for your bluetooth card. This is either integrated in your computer or you are using a USB dongle.
Through the bluetooth software within windows 7 or a alternate program provided with your bluetooth card you can look for your sennheiser. This is colled pairing.
There are thousends of methods to pair so read the manual of your computer (bluetoothcard or dongle) aswell as the MM100.
Good Luck
2helpful
3answers
Is BW 900 Sennheiser compatible with Windows 7?
according to Sennheiser, it depends on the compatibility of the usb device driver of your bluetooth adapter in Win7 (it is NOT a BW900 problem in their opinion)
as I understand it, you have therefore to by a new adapter and see whether it works with the BW900. Take the device AND your computer to the shop and have them install and pair
2answers
Bluetooth 2.1 USB nano dongle no driver
Click here to download the driver.
Now install it on your windows 2000.
Note: Windows xp will automatically recognize your dongle without external driver. I personally recommend you to use xp
Wishes .. :)
4helpful
My laptop which has windows 7 on it does not recognize mmy dongle
there is an update for windows 7 and dongles at the husqvarna viking website.
From Husqvarna Viking website -
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
link to latest Dongle Drivers - http://vsmsoftware.net/downloads/HASP/HASPUsersetup.exe
Husqvarna Viking - http://www.husqvarnaviking.com
If you are still unable to get it to work, visit your local authorized Husqvarna Viking dealer. Most stores have staff who are eager to help but you might want to call for an appointment
Good luck..
2helpful
Loaded autodigitizing onto our new computer with Windows 7. Everything loaded just fine but when I try to open program it does not recognize the dongle.
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
I could not install driver in vista
It is suppose to be plug and play. Vista advantage is you need not install drivers for most if not all external hardwares.
Try letting the system locate the phone itself.
Rate this please.
Motorolla HT820 Wount Connect With Laptop
What kind of driver u use for ur bluetooth? bluesoleil works ...
Keep getting the error "USB device not recognised."
This means that your license has run out. The internet talking kit was not free it had a temporary license and it expired, when you try to reload it, it does not work because a file has been added to your computer that prevents it from working without a vaild license. Now you have some options, use VMware create a virtual machine that shares this hardware without loading the program, ghost the VMware machine and then save this image. Load the USB drivers and the program, use for 3-4 months until the license runs out. when the license runs out use reimage the VMware machine with the ghost image and reload the usb driver and the talking kit program. Yes its a lot of work, or you can just buy the license load it and as they say keep on getting up.
Top Motorola Mobility Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
john h
August Brown
August Brown
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
