IE - Water level sensor fault
This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
There is a switch in the door latching mechanism that is not being closed rendering the machine useless. You have to replace the door latch mechanism. Go to attached site for parts Search Over 2 1 Million Appliance Parts
