More likely that it has dying power supply due to bad DC filter caps, that will be the first thing to look for. Basic LCD monitor troubleshooting guide: http://en.wikipedia.org/wiki/Capacitor_plague Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
