Watches Logo
Posted on Feb 09, 2018
The watch band holder broke so that the excess part of the band isn't held down. Can I buy just this part or the whole watch band? The watch is an Armitron Pro Sport, the only numbers on the back are M739 and 49/1003TI, the wrist band is solid black with 2 pins holding the band to the watch.
5 Related Answers
A
Anonymous
  • Posted on Aug 03, 2008
SOURCE: Shortening the Length of a Metal Wrist Band
Take your watch to a jeweler and they should do it for you free of charge.
A
Anonymous
  • Posted on Nov 02, 2008
SOURCE: Having trouble adjusting the time
i have the same problem still. go to the armitron website and find a telephone number then call it. I tried but it is sunday and they did not answer
Anonymous
  • 2071 Answers
  • Posted on Jan 08, 2009
SOURCE: armitron pro sport 49/1005, no
What instruction you want for setting ?maybe i can help you.
Anonymous
  • Posted on Jan 16, 2009
SOURCE: Armitron Pro Sport Watch Hourly Chime
Based on insructions for another watch, I just figured this one out. The steps would be:
Get in Alarm mode (press mode button)
Then you can cycle through the following by pressing the ST/STP button
1. Alarm on
2. Chiime on
3. Alarm and Chime on
4. Alarm and Chime off
You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 31, 2009
SOURCE: CANNOT SET TIME OR DATE AND ALARM
Follow this link and find instructions:
http://www.armitron.com/watch_instructions.asp
Rate, please.
My band broke on my AW60971w model watch and i would be interested in buying a replacement band
Have you tried a department store or jewelry store? I can not find any real information on the part number you list. Please provide more description of the watch.
Jul 01, 2011 • Watches
Plastic band broke at the end where pin goes ,is f...
Go to their web site http://www.fossil.com/en_US/shop/customer_care/static/fossil-orderlinks.html and you will arrive at a page with ordering info. on how to buy new bands.
May 14, 2010 • Watches
8helpful
3answers
The strap is broken on casio watch
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
2answers
Need new band. Where can I buy one? Thank you.
Any local retail store like Wal-Mart, Target, K-Mart. Just go to the Jewelry Counter find the band spinner measure the length of where the band is held with the watch.  Find your new band.  Usually everyone place have descent bands.  Ask employer there really helpful as well. Good Luck.
Pin that holds metal band clasp is missing
If it is only the pin that holds the metal band, this is an extremely inexpensive part that is available at most stores that sell watches.
Watch band links.
you would have to either have custom links made or buy a whole new band to be made the links pop out by pins and then shortened placed this way back together
but if you dont have extra links buying longer band is your better sollution cause creating a link or 2 to fits can be costly
8helpful
2answers
Replacement band for nike watch wa0018 oregon alt
I wear the smaller, womens' version of the Nike Oregon. Nice watch. I was attracted to it by the replaceable battery feature, but found out the strap goes long before the battery and the joy of ownership goes out the window with the price of Nike wrist-band replacement. I held onto my broken banded watch for awhile, and came up with a solution. First, don't try removing the screws that secure the watch-band pins. Not sure how they work, but I tried several times without luck. Even had a jeweler look at it without success.
I went to Kohl's and purchased a black velcro Timex replacement band for $8. Again this is the for the smaller version of the Oregon. The width of the timex band in 3/4". It includes a elastic band to secure the watch. This elastic band runs under the back of the watch and over the two pins. It is secured to a faux leather tab (with emblems), which is in turn attached to the velco band. Using a razor knife, I detached the faux leather pad from the velcro band and ran it under the watch pins, then reattached it with a touch of Gorilla glue. Be careful to wipe off any excess as Gorilla glue expands as it dries. Finally I blacked out the Timex advertising with a black felt permanent marker.
No reason to think this wouldn't work on the larger, mens' version of the same watch.
Top Armitron Watches Experts
Gene Lawson
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Armitron Watch Expert? Answer questions, earn points and help others
