Question about HP DeskJet 656 Thermal Printer
Why does hp d 1360 goes offline always - HP DeskJet 656 Thermal Printer
2 Suggested Answers
SOURCE:
  • 186 Answers
SOURCE: DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
Posted on May 28, 2010
Printer status always indicates offline unless I reboot. Only lets me print once then goes offline again. I have a Lenovo ThinkPad. Thakns
Delete the ICON of the printer
Restart the computer while the printer is ON
It should reinstall the drivers and then you printer will work fine
Jan 10, 2011 | HP DeskJet F380 All-In-One Printer
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
HP Deskjet 6943 driver isnt installing on windows 7 it always come with an error
i did not have the driver hp deskjet D 1360.plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz u give me driverplzzzzzzzzzzzzzzzzzzzzzzzzz
Jan 02, 2010 | HP Deskjet 6940 InkJet Printer
Always Offline
Turn off your computer and double check all your wires and connections. Also, make sure the printer is not sitting in power-save mode.
Dec 06, 2009 | HP Deskjet 3915 InkJet Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
HP OFFICEJET PRO 8500 GOES OFFLINE
on hp.com they have driver updates try just updating the driver
Jun 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
How to install hp printer
Hi, installing a new USB printer is not always that easy. If you have the installation CD, try to follow the on screen instructions carefully. If i'm correct you should install the drivers from the CD before plugging your USB cable and only connect it when asked. If your problem is different, let me know
Jun 05, 2009 | HP PSC 1315 All-In-One InkJet Printer
I lost lost the driver for my printer HP Deskjet D1360, i want to install the printer now.
I'd lost the driver for the HP Deskjet 1360 and the programme is not available in the computer. How can I run the Hp Deskjet 1360 with my existing computer?
Thk you very much for your suggestion if any.
Mar 30, 2009 | HP DeskJet 656 Thermal Printer
HP DeskJet 656 Thermal Printer Logo
57 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
