My laars Lite 2 was running fine but when checking the pilot had gone out and now can not re-light. The pilot lights but when I release the white button it goes out. Any ideas please
I am having the same problem. The heater was working fine and then one day when I turned off my pump to clean the screen, the heater did not fire up when ai turned the pump back on. I checked the pilot light and found it not lit. I have tried lighting it several times but everytime I release the control valve knob the pilot light goes out. I am wondering how you check the thermocouple to know if it is working properly.I am having the same problem. The heater was working fine and then one day when I turned off my pump to clean the screen, the heater did not fire up when ai turned the pump back on. I checked the pilot light and found it not lit. I have tried lighting it several times but everytime I release the control valve knob the pilot light goes out. I am wondering how you check the thermocouple to know if it is working properly.
I have a similar problem. I have a spark, but my pilot light will not ignite at all. And I don't smell any gas. Anybody have a guess as to whether this is the gas valve or the thermocouple? Thanks!I have a similar problem. I have a spark, but my pilot light will not ignite at all. And I don't smell any gas. Anybody have a guess as to whether this is the gas valve or the thermocouple? Thanks!
the pilot would lite first time but burner would not kick in on recomendation from jandy engineer i changed the water pump now using a marlow itt 1hp, after fitting the burner kicked in for approx 3 mins now i have no pilot and no main burner, i have had this unit for 1 month from new and it has worked for approx 3 minutes i could heat more water with a candle, stay away from Jandy. the pilot would lite first time but burner would not kick in on recomendation from jandy engineer i changed the water pump now using a marlow itt 1hp, after fitting the burner kicked in for approx 3 mins now i have no pilot and no main burner, i have had this unit for 1 month from new and it has worked for approx 3 minutes i could heat more water with a candle, stay away from Jandy.
You can't post conmments that contain an email address.
If you have not found the problem yeat, it IS the thermocoupling( or pilot generator(same thing))
You may test by placing a multimeter on the red and white leads coming to the gas valve. you do not need to disconnect the leads first but you can
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
it might be the hot surface ignitor. a common problem with gas furnaces also. also, check if there is an code on your screen. it will be called an FL code. call the manufacturer.
