I have kenstar convection model microwave. the start button doesn't work after pressing any other button like microwave, convection and grill etc. Basically the top few buttons. but it is working with convection button. what could be the problem?
To cook an individual frozen pie in your Panasonic convection/grill/microwave, you can follow these steps:
Preheat the oven to 375°F.
Remove the pie from its packaging and place it on a microwave-safe plate.
Place the plate in the center of the microwave and close the door.
Press the "Convection" button on your microwave and set the temperature to 375°F.
Set the timer for 25 minutes.
Press "Start" to begin cooking.
After 25 minutes, check if the pie is cooked by inserting a toothpick into the center of the pie. If it comes out clean, your pie is ready! If not, continue cooking for another 5-10 minutes until it is fully cooked. This is a general guide and there might be variance with your particular device.
Press convection button, then press button with temp you want, then press start to preheat. Once preheated, either press cancel once, to allow time to be input, or engage door button, an press Time and enter your cooking time. Then press start again
If you press "convection" the oven works just like a regular oven except that the element is on top. In "microwave" it works like a microwave oven. All you have to do is decide which mode you want to use and then punch in the time and hit "start". The glass plate is not really a necessity as long as you make sure there is a load in the oven when you are "microwaving".
I have a simular model and I found that the circuit board has three black relays, one for the grill one for the convection and one for the microwave. I found that the microwave one wasnt working so by swaping the microwave one with the convection one I got it to work and then replaced the faulty one with a new one at a later date.
The options for language selection will be detailed in the setup menu in the manual. German and English are similar enough to work out the steps to return it to English. A manual can usually be acquired from the manufacturers website, or from download sites. (Internet search your brand and model number).:::Spiceweasel.au.
