SOURCE: how do i resolve the error: use genuine battery. power off
My phone did the same thing, and i took it to verizon and pretty much told me to screw myself. I looked online and someone said alcohol bath. I took the battery out put the phone in a bowl of rubbing alcohol for an hour. THen i let it dry by the window for an hour overnight and boom it was fixed. No more problem
SOURCE: My LG VU CU920 keeps turning off
I had the same problem even after I exchanged the phone for a new one. The problem seems to be related to Mobile TV and the SD memory. When I removed my 2GB SD memory, the problem has not reoccurred. I recently installed a 512MB SD memory chip and so far I have not experienced the problem.
SOURCE: lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
I took out the battery on a lg verizon phone oops put it back in now black nothing ?? There must be some sort of way to replace the battery that reinitializes it any help
SOURCE: LG PC Suite does not detect the LG KS360 phone!
I have an LG VU and I get the same message using the LG software. I think it is pretty much useless for a lot of LG phones. Try connecting with just a data cable. The pc should recognize your memory card as an external drive, and then you can transfer your files quite easily back and forth.
SOURCE: Click on the LG Dare display settings button and the phone resets
all you do is go into your security and settings and reset the phone. it will turn the phone on and back off again. but this should fix the problem and restore the ability to get into your display settings, as well as view your date and time.
