If the Dell Diagnostics passes then the issue is in the software part of the computer.. You may have to reinstall the OS inorder to address this issue..
Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If this option is not available then reinstall using the disc
The issue will be fixed
Testimonial: "Your suggestion worked! Thank you so much!"
It worked! Thank you so much!
