Question about Frigidaire FEF336BC Electric Kitchen Range
Have a gas stove Frigidaire proofessional series..... no manual Came with the house. Just tried to do the self cleaning...... with in the first hour got an F30 Err message...... turned it off...... now door is locked and if I try anything else except clean. it wont work. If I push clean...... I get the error message back. Cannot open oven door. Any Suggestions? Is the oven still cleaning and should I turn off the electric to the stove? Model number CPCS389EC3
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Frigidaire Master
  • 102,366 Answers
Http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318203863en.pdf
Posted on Apr 28, 2011
SOURCE:
Directions how to use self cleaning over on the fridge re gallery gas stove
Hello, Joan -
Clarification: You are asking about a Frigidaire Gallery model gas stove and how to use the self-cleaning feature for the oven? If so . . .
You will find the instructions here:
https://www.hunker.com/12002208/instructions-for-a-frigidaire-gallery-series-self-cleaning-oven
If you need the user manual for your oven, you can add the model number by choosing Comment and adding the information there, so I or someone else volunteering to answer on Fixya.com can look for and provide the right link for a download of a free manual.
Note: There is more than one Frigidaire Gallery range model numbers made:
https://www.frigidaire.com/Kitchen-Appliances/Ranges/View-All/?filter=Feature02012:Feature02012
Best wishes.
Apr 06, 2018 | Kitchen Ranges
Fridgidaire stove clock not keeping correct time
Clock logic can not be changed replace the whole board
just lets you change the time will not let you slow it or speed up
Nov 14, 2013 | Frigidaire FGGF3054KF Gallery Series...
No instructions on how to use self cleaning Frigidaire range/oven
stove stuck in self cleaning mode door was open when cleaning mode was turned on will not shut now what do i need to bdo?
Feb 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My stove has been self cleaning for 2 hours and I caqnt get it to stop. I tried turning off the electricity and it still keeps going. What do I do?
Many of the self cleaning processes take up to 6 hours. The best suggestion I can give is to turn off the gas valve if you can safely access it and unplug the stove. Chances are the oven door will not open till it cools down for a couple hours.
Sep 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
I did not follow directions on self-cleaning and now stove is loc
Since the door is open and the lock is engaged, you will need to hold the "door closed" switch in located in the top left door opening. Push and hold the switch in, push the clean button, set the time at 3:00 hours, keep holding the switch in for 20 seconds, then push cancel button. The motorized locking mechanism should disengage. Then, you can release the switch. Hope this helps.
Dec 06, 2008 | Frigidaire FEF352 Electric Kitchen Range
Frigidaire Self Cleaning Stove
Yes you have to set the timer. If it is like my stove/oven you have to set the time to start and the time to complete. normal cleaning 3 hours heavy cleaning 4 hours light cleaning 2 hours.
May 29, 2008 | Kitchen Ranges
How to clean gas oven
hi,
use a 2 hour self clean cycle for light soils and a 3 hour cycle for heavier soils. The kitchen area should be well ventilated using an open window, ventilation fan or exhaust hood during the 1st self clean cycle. This will help eliminate the normal odors associated with the 1st self clean cycle.
when the controls are set, the oven door will lock and the “LOCK” indicator light will flash. DO NOT open the oven door while the light is flashing
Mar 29, 2008 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
179 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
