Archos Clipper MP3 Player Logo
Posted on Nov 22, 2010
I have just bought an Archos Clipper mp3, I have drag and dropped music from Itunes to the Archos folder which comes up onthe desk top after pluggin it in, the music then copies across and is in the archos folder. But when I try and play it, only a few songs are on there? Does anyone know how to fix this? Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
449
Points
I have the same problem when I try and copy tunes from my Mac. If you go into the archos file you can see them but cannot play them. How did you solve it?
Why can't I get itunes music onto this thing
You have to drag and drop songs from your itunes library. It also helps to place the music in different folders. When you plug the player into your computer, it should ask if you want to open the files on the player. Do this, then select to make a new folder. Open the folder, (there should be nothing in it.) Then drag the songs from your itunes library to the open folder of the player. When finished dragging songs, make sure to close the folder on the player, then to safely eject it from the computer. All songs purchased from itunes are in AAC format. You will need to convert the songs to mp3 format before dragging them to the player.
Hope this helps. This is how I get songs onto my mp3 player. Itunes is so much easier the windows media player.
tip
How to transfer windows media player muisc to iTunes
You may have some music on Windows Media Player, and you want to add them into iTunes library for your new iPod or iPhone. Or you may want to move your iTunes bought music to Windows Media Player for portable devices such as Zen, Zune, Phone, Sansa, Archos, MP3/MP4 Player, etc. It’s easy to do that. And this guide will show the steps to do the job.
Part1. Transfer Windows Media Player music to iTunes
Step1. Open iTunes and select the File -- Add Folder to Library menu.
Step2. Browse to your Windows Media Player music folder. iTunes will ask you where your songs are located, which by default will be in your My Music folder on Windows XP, or in your Music folder on Vista.
Step3. Convert Windows Media Player songs to AAC format (.m4a). If you have files in WMA format, you will be prompted to convert those WMA files to AAC. This is a necessary step if you want those tracks available to play on your iPod or iPhone. If you have a large music library in WMA format, converting WMA to AAC may take a long time. Plan to do this at a time when you can leave your computer on and walk away to do something else for awhile. You can also import your WMA files as MP3 instead, which also allows them to work with your iPod, but makes them more portable if you buy something else in the future.
iTunes doesn't modify your original music files from Windows Media Player. It leaves those songs in their original location and makes copies in your iTunes music folder.
Part2. Transfer iTunes music to Windows Media Player
Because iTunes music has DRM protection, you can't easily import the music into Windows Media Player by drag and drop. There are two ways to transfer protected music from iTunes to Windows Media Player.
Method1. You can use iTunes to burn the music to a blank CD at first, then use Windows Media Player to rip the music CD, the DRM protection will be remove during the ripping process, then you can rip the CD into WMP library. This way is good for tranferring a few music. For large mount of music, it would take a really long time to transfer music.
Method2. If you don't have blank CD disk or you have many iTunes music need to transferred to windows media player. You can use DRM Media Converter. It can legally convert the protected iTunes music to non-protected MP3 music, then you can easily drag and drop the MP3 music into Windows Media Player.
Step1. Download and install the DRM Media Converter , the file size is about 7 MB. I have scaned it with Norton Virus protector and AVG spayware protector, it's safe without any warning.
Step2. Run the DRM Media Converter, Click Add to import iTunes music, which by default will be in My Music\iTunes\iTunes Music .Or you can run iTunes, click Edit -- Advanced Tab, there you will see where your iTunes media folder location.
Step3. Set the output audio format as "MP3 - MPEG Layer-3 Audio (*.mp3)"
Step4. Click Start to run the conversion, it will take a little bit time to finish the job, then click Browse to located your converted mp3 files, drag them into Windows Media Player, done.
on Feb 05, 2010 • Computers & Internet
2answers
How do I download music from iTunes to my mp3 player?
HEYA
First of all open itunes
Link your MP3 player to your computer while the iTunes software is loaded on the computer. By itself, iTunes serves as an audio player for your computer. You can transfer audio files to your MP3 player using a USB cable which comes with most MP3 players. Your computer will prompt you to name your MP3 player, and an icon identifying it will appear down the left margin of iTunes.
Click on the MP3 file (the song), and drag it into the "Library" folder in iTunes. This folder will serve as the general place to store all the MP3s on your computer. From there, you can create new playlists to select specific songs, click on the "shuffle" option to have iTunes randomly select songs to be played through your computer, or play every song in order from the library.
Select the appropriate song or playlist, and click the "Play" button on iTunes to listen. Or drag the songs from iTunes into your MP3 player's icon in iTunes to copy the song into your MP3 player.
Long live the geeks!!!!!!
Tried to download 50 albums to i tunes library,mp3
yes, try ripping the cd or dvd by placing in tray........open itunes and rip the track (s) you want...(itunes will convert the mp3 to mp4)....once all your track you want are done.......take the music file from the top of left hand side (make sure ipod is connected for this) and click hold and drag down to the ipod music folder (this will take a while depending on large the folder is) once you are finish never ever just unplug it you will lose your files EJECT from itunes............
HOW CAN I DOWNLOAD MUSIC VIDEO AND VIDEO TO MY ARCHOS 604
screw that software. When you plug in the archos the archos asks what your doing with it. Say Hard drive mode and then you can drag and drop and file you want onto it.
Its pretty simple put movies in the movies folder and mp3s int he music folder lol.
11helpful
2answers
How can i put music on my Archos 5?
Once you connect your archos 5 to the computer, it will ask you whether u want to "enable USB' or "charge only"....select enable USB (OK). then go to "My Computer", and you will see a graphical image of the archos 5, under the name "portable devices"..
Double click on it, until you get to the "music" folder..and once you open this folder, you cn start copy-paste....- where you copy the music file from a folder in your computer, then paste it to the 'music ' folder on your archos..and you're done!!!!
peace..!
Roscoe
1helpful
How to put music file in my ipod nano 4G in XP? thanks
Hello, please go to apple.com
Download iTunes and install on your computer.
Once it's installed, connect your ipod to the usb cord and you will see it come up in the iTunes screen.
you can create a playlist and sync it or you can drag and drop songs to the music folder by checking the "Manage Music Manually" box.
Download you music to your computer, open the folder over the iTunes window and drag n drop the songs into the music folder or the first column of the white area in the big window.
when you drag a song or group of songs, hold over the first column of the white area till you see a blue outline and drop..music will load automatically.
If this helps you please leave a vote
1helpful
Itunes library wont all sync onto ipod
first the easy part....1800 songs we will not move this one at a time..............plug ipod to pc..open itunes....see on left hand side of screen...pc (music,photo & video folders) and under that ipod (music, photo, video folders)..ok..click on pc (music folder) all your music shows up right ok..this time click & drag the pc (music) down to the ipod music folder and release....its 1800 songs so lets wait til the ipod is finish (look at the ipod file a circular motion is happening,,,,its loading).......once finish always eject your ipod...............now find where you are storing mp3 / mp4 on your pc...once you find it ..go to top bar view then click,on view details (artist,album,type,lenght) this where it will say mp3/4/wma/wav or flac file
How do youtransfer itunes music to a sandisk player
Download the song to your computer's iTunes music folder. Then drag and drop it into your SanDisk's MUSIC folder with the MP3 set in MSC mode.
How do i put music to my archos?
try going in to whatever music player program your computer offers and to to file.... browse...... my computer..... and there should be a usb drive if its pluged in it will say archos.... click on it...... and select open.... then it will come up you can then transfer music to it just like any other drive or folder on your computer try windows media player go under the sync option then just drag and drop
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
