US Night Vision Ultra PVS-7B Goggles Logo
Posted on Nov 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I recently accuired a pair of an/pvs-7b night vision goggles. When trying them out they didnt work. I checked the batteries already in them, there was no old crusty battery acid. I replaced them and still nothing. I read on how to adjust the dioptre. still nothing. Whats the deal?
Anonymous
Level 3:
Master:
  • Master 577 Answers
  • Posted on Sep 24, 2011
Anonymous
Master
Level 3:
Master:
Answers
577
Questions
0
Helped
218759
Points
1089
Hello, there two things that can bad. One is the oscilator with voltage multiplier or the image intensifier tube. Send to Morrison Optics Co. GB....stewbison
Is VFR with night vision goggles at night dangerous for civilian pilots?
14 CFR 61.1 (b) (12) and (13) Definitions-Night vision goggles and operations. 14 CFR 61.31 (k) Additional training required for night vision goggle operations. 14 CFR 61.51 (k) Logging night vision goggle time. 14 CFR 61.57 (f) Night vision goggle operating experience. 14 CFR 61.57 (g) Night vision goggle proficiency check. 14 CFR 61.195 (k) Training for night vision goggle operations. 14 CFR 91.205 (h) Instrument and equipment requirements for night vision goggle operations.
Jan 04, 2017 • Aircrafts
I have an/pvs-7b night vision and need to replace my battery cap. The metal piece in side broke off???
Considering many vendors who sell parts are going to have a minimum order, Night Vision Depot for example has a 100 dollar minimum; you might consider trying to repair your old one or fabricating a new one. Otherwise checking on Ebay for one. On the other hand if you can fabricate a new one easily, you might consider being a vendor of that part too as you would not be the only person to encounter that dilema.
Unit simply does nothing when its turned on. the IR assist still works. (AN/PVS-7B/D
Letto, This PVS-7B has a generation II image intensifier tube in it. The image tube is manufactured by ITT liton company. The only way to fix this wonderful NV devise is to send to ITT Night Vision Company. They are listed in the internet. Unless you can find someone to work on it, but the really need to know what they are doing. stewbison
My pvs7 wont stay on thay shut of after 30 seconds and then start to shut of ever few seconds
Hello, have you or someone else pointed this night vision devise at bright lights, street lights, head lights. If so, maybe the damage has/hasn't alread been done. STOP. This PVS-7 goggles with ITT image tube with generation 2 or 2+ or possibly generation 3 tube. The devise is an American made unit, and the best in the world. Nobody can compete with the USA on NV. They sat the standards on Night Vision.
Have you replace the 6 volt battery? Get the goggle in a darken room then turn the switch on.
see if the 25mm plate will turn green and stay on. But first replace that battery.
Therefore, if this test works, then never and I mean never shine NV devises into bright lights, it will destroy them every time.
PS. send me another message and let see what happen. stewbison
I am having trouble with my pvs 7 night vision. I can see clearly for about 60 yards. The IR illuminator is not working. What do I need to do?
OK, is the IR luminator working with a red glow. Don't look at it. Some these IR luminator have a adjustable lens that one can screw out or screw it in. If the IR isn't igniting then the LED could be bad , broken wire, or bad switch. stewbison
Looking to buy a used pair of pvs 7 nightvision goggles and owner says there are a couple of small black spots when you view is this a cause for concern and what else should i look for ?
Hello, that is normally to have some black spots. Now, if tries to tell that this Military spec. He wrong. Two black spot on any image tubes used by the US Military is rejected, they only allow one black spot and that if everything else is OK. How fuzzy is around the outer circle of the image tube. If there is a uniformed green pattern through out the scope. I would say it was OK. But remember "Buy be Aware". GB...stewbison
2answers
Put it together myself now wont focus past 5 ft and has double vision i tryed using the adjustment knobs and stillno luck
loosen the the thingy behind the lens adjustment, you can turn it clockwise or anti-clockwise which it will go down or up, thats it..problem solve for your 5ft focus problem..in the double vision, you gotta line up the eyepiece center to your both eyes..problem solve again
Apr 29, 2009 • Optics
Powering down
How long have you had the system? Did you purchase from USNV or private party? If from USNV why not call them up and send it in for repair. If from private party,,,,,that's the chance you take. Sounds like you have either a failing power supply or an electrical short somewhere. In any event the system should be looked at by somebody who knows about night vision. If purchased within the past 2 years it will still be under warranty.
Top US Night Vision Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an US Night Vision Optic Expert? Answer questions, earn points and help others
