Printcopy.infohttps://printcopy.info > model=Di2510
Code: C0045 · Description: Cooling Fan Failure The Cooling Fan Motor Lock signal remains set to H for a set period of time while the Cooling Fan Motor is ...
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
You can try to reset the C0500 error code press the soft initialization on the right side of control panel
when the dot appears on the lcd after reboot press the number 3 key the mode will change to the initialization screen choose the selection for trouble reset after reboot the code will be cleared
power on and of for basic screen if this dose not work you will need to replace the fuser unit
in regards to your c0f32 code the toner to carrier ratio is wrong this is caused by the wrong developer being used clean out developer unit and put correct developer in the unit
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
