Try this.
Plug your BB into the charger.
With it plugged in take the battery out.
Wait a minimum of two minutes then put the battery back in.
Let it charge for a minimum of an hour before touching any keys or the trackpad.
If it still won't charge consider replacing your battery.
SOURCE: blackberry pearl wont turn on.
Maybe try a soft reset by pressing ALT-CAP-DEL
It might reboot for you.
SOURCE: blackberry pearl won't turn on
The sim card may not be put in correctly, or it may need to be slid back or fourth a little bit. I had this same problem, but continued playing with my phone until I figured it out, now of course with a blackberry it took awhile to come back on, but no more irritating red light and black screen. Voila!
SOURCE: Blackberry 7290 - Will not trun on
Unit is defective or the software needs to be reset/reflashed.
- J.
SOURCE: my blackberry pearl 8100 wont turn on
The real problem:
BlackBerries have issues with power management, especially if they get fully discharged batteries.
The real solution:
Unplug
Remove battery for at least 10 seconds
Re-Insert battery
Start er up and use your phone!
SOURCE: so my blackberry curve just crashed
what has happened is some file some where is corrupt. It any easy fix really, just download your current os which you can find by holding down alt and then type eace and that will bring it up. download the os from here www.blackberry.com and then connect and reload your os
