Error 10-FC12-0570 on Toshiba satellite
This error message means that the recovery utility was not able to read
the data from the disc correctly, or wasn't able to write it to the hard
drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try
copying the second disc using another system. If it's impossible:
order for a new disc. If you can copy it, try using the copy to do the
restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista
Recovery Boot Cd is available free by Microsoft). Download it burn the
Image .iso and run that disc. That disc will not restore the OS: run
diagnostics on the HDD; once disk check is completed and repaired,
proceed with the Recovery disks that you have.
HI
A Code 10 error is generated when Device Manager can't start the hardware
device, a situation usually caused by outdated or corrupted driver A device may
also receive a Code 10error if a driver generates an error that Device Manager
doesn't understand. In other words, a Code 10 error can sometimes be a very
generic message indicating some kind of unspecified driver or hardware problem.
Uninstalling and then reinstalling the drivers for the device is a likely
solution to a Code 10 error. If reinstalling driver is not working than try to
rollback the driver or restore the system on previous date..
regards
sandy fixya
