I had that problem and solved it by removing the red "STOP" cover. The cover pushes against a switch. If the switch moves too far down and rests against the cover, it will be stuck in a lock position causing the error message. To remove the red STOP cover, remove the few screws behind the console. When the front cover is off, turn it over and unscrew the two screws that hold the red stop cover. Then push the cover out through the FRONT. Do not attempt to lift it out by the end with the screw holes. It iwll not pull out that way. Test the machine before screwing the panels back agian. The message should no longer show STOP KEY. Test the visible white small switch that you uncovered by removing the red flap. The message should stop when you press the switch.
I kept the red STOP cover off of the switch and screwed the panels back into place. The machine now works fine!
No it is stop key
just easily open the console and visually check under the magnet holder from inside you will see there rust ir broken cable
also using more powerful magnet key also helps
