Kohler - Toilet - One-piece - Santa Rosa - K3323-52 Logo
Posted on Nov 22, 2010
Trying to change the toilet seat,however cannot remove the screws. They come out about maybe 3/4" and keep spinning. Looking inside the tank as well as feeling inside there are no nuts connecteing to the bolts. Any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Dec 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
9739
Points
51
Try using some upward pressure on the bolts while turning them, using a pair of Channel Lock pliers (aka arc-joint pliers). This may stabilize the nuts into which the bolts are threaded. When installing the seat and reinstalling the bolts, a downward pressure may be required into to tighten them properly.
2helpful
Replacement seat....size???
American Standard is the brand, so you've got a start there, but 1.6 is a flush measurement. Look around the inside for a tank for a model number - with AmStan toilets it's usually a four digit number beginning with a 2 or a 4. This will be what you need to get the OEM toilet seat. However, since toilet seats are purely cosmetic (they don't affect the functioning of the toilet), you can literally take a few measurements and find something that simply keeps you off the porcelain. http://www.plumbingsupply.com is a good one for toilet seats, btw.
Aug 21, 2012 • Home
tip
Toto SW834r Remote Control Problem
Note: Toto does not sell parts and requires dending in a unit with a maximum repair price of $300 as of 1/.2015If after replacing remote batteries the seat still does not respond, try the following:1. Turn off the water shut off valve at the wall and unplug the power.2. Unscrew the water inlet hose to the seat.3. Unsnap the seat from the toilet by pushing the quick release on the side of the seat neat the hinge on right side facing the toilet.4. Bring the seat to an area you can get dirty (outside) and remove the two stainless screws on the rear of the seat.5. Carefully unsnap the cover  (four plastic clips inside the cover)6. Clean everything inside and out including water filter on side (unscrews), air filter underneath, top of toilet,  and rinse and allow to dry thouroughly.7. While drying carefully unclip the remote sensor and remove the connector by holding the lock and pulling straight off. Confirm there is no corrosion on the connector. Use a contact cleaner/protector and clean the contacts and replug in the connector.8. It is also recommended to do the same for all of the other connectors.9. Put everything back together.10. Replace hose and plug in power and allow "restart" to finish11. Test remote to see if remote "talks" to seat before turning on water.12. Turn on water and wait for inner tank to fill.13. Manual controls on side of seat can be used to confirm unit is working.  After confirmation the remote should work normally.14. After this procedure my SW 834r worked perfectly......  enjoy.
on Jan 26, 2015 • Home
I have a koehler rialto toilet and am unable to replace the seat as the screws keep spinning and there is no way to access the bolts form underneath as the toilet is totaly sealed. Other than replacing the...
Wrap a putty knife with a wash cloth, and push it between the toilet ceramic surface and the plastic hinge for the seat. Wedge it in there. Now try unscrewing the hinge screw. This provides back pressure against the hidden nut on the other side and may let you successfully remove the screw.
One screw from seat to tank,trying to change seat, turns and turns without coming up, the other doesnt turn at all and is starting to strip head. I tried putting pressure under screw to give it something...
Here's an idea----If the hinge piece is plastic, cut it away to expose a bit of the bolt and use vise grips and pull. Maybe put a thin metal plate next to the bolt so you can pry up on the vise grip. Or maybe you can get a grip on the hinge itself with the vise grips. The insert is going to be plastic, so if you can get a grip this should work. Or you might try drilling a small hole in the hinge piece very close to the bolt so you can get some super glue down in there to lock the insert is place. Hmmmm, this might be a bad idea unless you have a hypodermic needle and bolt is not plastic. good luck!
3helpful
2answers
Toilet seat
Here's what I did. Unscrew them as much as possible. Then I used a bolt cutter and hacksaw to cut away as much of the plastic seat holders as possible. I could then remove most of the seat, and get better access to the screws. I then raised the loose screws enough to cut them with a bolt cutter. Soft screws cut easily. The screw heads are now out. Now, tap down on the screw/anchor and it falls into the bowl. It will stay there. The remaining problem is that you need anchors to secure the new toilet seat. Kohler wants $50. I have a usable but loose seat. Never again-Kohler.
I strongly recommend using a boltcutter. A hacksaw will tear up the bowl.
Seal between tank and toilet are leaking
Purchase a new flush valve at hardware store.
You'll need cresent wrench, locking pliers, small pipe wrench, small pail, towels, putty knife.
turn off water supply, flush toilet to remove water from tank, soak up remaining water with towel in tank, remove supply line from valve on botton of tank (you may have to hold valve with pliers inside the tank to keep from turning.) Clean area inside tank with putty knife where new valve will seat. Install new valve, attach supply line, connect overflow tube. turn on water.
Check for leaks.
Repeat if necessary. :-)
4helpful
2answers
Toilet seat come loose and no obvious way to tighten??
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
9helpful
5answers
Kohler lowboy toilet seat does not have bolts underneath
I have the same low boy where the bolts are inside the hollow body of the toilet. I called Kohler customer service and was told to use brute force to yank the toilet seat out. My husband suggested using a saw to cut the bolt but he hasn't done it yet. He wants to replace all our Kohler low boys which constantly leak becos of poor design of handle and flapper. The handle pulls the flapper slightly to the side when you flush. And the flapper lip being a tiny bit too small, if it doesn't sit just right, the toilet leaks. We've replaced one already with a Toto and love it. Too bad that Kohler isn't trying to fix the problem as I see many many online posts with the same problem and recommendation to replace the Kohler with Toto or somethng else.
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
