Hi Jeff:
Two things affect the water level in the bowl:
1) - The maximum height is determined by the siphon. To see if that is where you are, slowly pour water into the bowl. If the level stays the same, that's the maximum height. If it increases, you may be able to "tweak" the trickle tube. (next step)
2) - "Trickle tube" - My term as that's a good description. Lift the lid off the storage tank. If you look into it you will see a vertical tube, open at the top. A small tube should be clipped on to it so that when you flush it, water from the small tube flows into the big tube. That will be "trickling" into the bowl to fill it to the top of the siphon level. Sometimes this small tube can be installed so that it misses the big tube so the bowl does not get filled to the maximum.
- Hope this helps.
Cheers..
On the fill valve float there will be either a plastic screw or a metal bar with a metal slide clip on it. If its a screw, use a screwdriver to turn it cw or ccw to adjust water level. If its a clip, compress the clip between your thumb and forefinger and slide it up or down along the bar to set the float level. You need to test it after adjusting. Level should be 1/2" below top of overflow tube.
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Try adjusting the float level. The float is what tells the toilet to stop filling. If the float is set too high, then water will just go down the overflow tube and never be able to get to the level it needs to turn off.
Adjust the float attached to the fill valve. Some simply slide up and down on a racheted adjustment bar. Others screw up and down for adjustment. Flush after each adjustment until the proper fill level is acheived. Make sure there is still a sufficient amount of water at a given level to flush the toilet properly.
My Kohler Ingenium has no pins. The white cap is attached to the grey lever which must be lifted up before twisting both one-eighth turn counter-clockwise, and lifting off of fill tube. Turn the water supply back on and flush the tube out (cover with cup first!). Use a thin wire rod about 12" long to gently poke down into fill tube to clear any clogs. Also check where the small flexible fill tube exits from the main fill tube. Reassemble and cross your fingers.
