Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi,i own a dinli t-rex dl-601 100cc atv quad bike and i recently changed the v-belt,cleaned the carb,wahed filters,drained and changed engine oil,drained and changed petrol,drained and changed 2 stroke, basically stipped it and serviced it. when i start it now and give it some throttle the quad struggles to move(even with full throttle)and after it gains a little speed it kinda kicks in and then goes pretty much as normal.it actually struggles to get up steep hills as it seems to loose power.i actually have to push it to start it moving sometimes as there seems to be no power until a certain speed. can you help?
  • Terry Hoyez Sep 28, 2015
    I have the very same issue on my Dinli. 900cc
Frank Antonowitz
Level 2:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 47 Answers
  • Posted on Oct 21, 2015
Frank Antonowitz
Expert
Level 2:
New Friend:
Teacher:
Answers
47
Questions
0
Helped
6213
Points
137
I think you might want to change catagories, I found this under Bicycles. Also, I was curious as to how you can list it as a Quad Bike . . . Bike is a short term for Bicycle, Bi meaning 2 as in 2 wheels.
3 Related Answers
Anonymous
  • Posted on Jan 24, 2010
SOURCE: Alini pocket quad wont move
Have a look at the choke lever. From the starting position, move the lever about 10mm up until you hear a slight click. If not then the clutch plates are not responding to the throttle input. Any lawnmower repair garage will be able to help you more. The 2 stroke works on centrifugal clutch, that is the clutch plates move outwards when throttle lever is pulled. It is a bugger to start. I've got blisters on blisters from the pull cord. My son is 10 and he may well be a little big for his but when it goes, it is fast enough to start kids off with motor bikes. Hope it helps.
Anonymous
  • Posted on Apr 20, 2010
SOURCE: I have a madami t-rex 90 quad that sounds like it
bruce i have the same problem! and i cant find ANY parts. what did ya find out? [email protected]
Anonymous
  • 944 Answers
  • Posted on Feb 17, 2011
SOURCE: my quad when i push trotle it spluttrs and no
It is the carburetor problem just clean it.If you have good hands on you can itself do it,else take it to the mechanic.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
1helpful
2answers
Atv has no power, 50cc two stroke Dinli. It will start and idle, but when you give it more gas to move, it wants to bogged down and stall.
Could be your reids iv had same situation cleaned carb numerouse times new spark plug kept doing it turned out it was the reids on my dino 50
1helpful
Hi, anyone know what the factory carb settings are for an aeon mini kolt 50cc. Having problems with getting it started, changed spark plug and battery
Two-Stroke Scooter / ATV Carburetor Settings And ...
? 4:37
https://www.youtube.com/watch?v=A1vRMERs4RQ
Jun 2, 2012 - Uploaded by 90GTVert
Part 2 of a 4 part video detailing all of the basic settings and ... Two-Stroke Scooter / ATV Carburetor Settings ...
Fix your Mini bike Carb - bogging, cutting out etc - YouTube
? 4:51
https://www.youtube.com/watch?v=lbtDMFUiD0k
Aug 15, 2011 - Uploaded by Cpt MishMash VonRandom
If you are having trouble with your mini bike/quad whereby its difficult to ... Two-Stroke Scooter / ATV ...
quad 50cc carb Questions & Answers - Fixya
www.fixya.com > Forum > Tags
50cc carb wondering what the factory setting is for a 2002 50cc Kawasaki kid's ...aeon mini kolt 50cc quad will rev a little then cuts out no power Likely a lean ...
Aeon mini kolt 50cc quad will rev a little then cuts out no ...
Cutting out
Hi Thomas only thing I can think of is that its not getting enough air is it the right filter as it may be not be allowing enough air through. As you probably know if you don't get the right amount of fuel & air it won't run right. Hope it helps cheers Paul
Jan 23, 2014 • ATVs
Engine wont start on mini quadard 49cc model atv-2
A lot of guys are having trouble with that. If you have spark. disassemble the carb and clean it. then screw the set screw all the way in and back it out 1 1/4 turns. if you need more you do it in 1/4 turn increments.
I have an 49cc ATV midi quad bike and it will not start at all. Have changed the flywheel and pull cord and carb, but still have no joy. Have used easy start too! please help, had it over a year never bin...
I had this same problem. I had a very hard time to start this quad untill i was told to make sure the fuel filter is half full with gas. Which it wasnt getting gas through the filter. So i went down to our local dealer and purchased another filter. The new filter was getting gas this time but the quad still did not start. So i was told to take the throttle cable off the engine and pur gas right in the hole, but the cable back on, Put the choke on full make sure the gas valve is turned on and fire it up. it started right away. But i had to repeat this a few times. But works now
Ed
5helpful
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
8helpful
2answers
Quad bike keeps cutting out
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There may be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Top Quad Cycling Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Kardoc
Are you a Quad Cycling Expert? Answer questions, earn points and help others
