Lower element can be burned out and still read 230V across screws
1) We know thermostats are working because elements test 230V.
2) We know upper element is working because tank has some hot water.
If upper element is burned out, tank will have no hot water.
http://waterheatertimer.org/How-it-works.html
3) Here's how to test lower element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
4)Here's how to replace element
Rheem element is 4500Watt bolt-in type
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
5) Rheem manual says: Heaters furnished with standard 240 volt AC, single phase non-simultaneous wiring, and 4500 watt upper and lower heating elements.
http://waterheatertimer.org/pdf/Rheem-spec-sheet.pdf
Rheem 4500Watt element
Photograph error: Rheem uses screw-in elements. Open panel on side of tank to identify type of element. Take photo of element to hardware store or home center to buy matching element. Element wattage and voltage printed on label on side of tank and printed on end of each element.
