The most common failure in the DLP that makes a whining sound would be the color wheel. They cost about $135 + labor because I wouldn't advise changing it by yourself.
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
