SOURCE: The crown on my Luminox 8362 doesn't push and pull
If it's like my Luminox 1828, the crown has to be unscrewed before it can be pulled out and worked like a regular crown. Just don't forget to screw it back down afterwards.
SOURCE: Just bought a nice LU3007
I don't know your watch but as an engineer, I would expect there to be a single position where the crown can be pressed in.
Try applying a gentle pressure to the crown while you are slowly rotating it an you may be able to find a spot where it hits and slight depression, (a soft touch required here). When you find this spot, press the crown firmly and then rotate.
If you still have no luck, try speaking to the supplier to find a local repair center who should be able to give you some knowledgeable advice, as I feel sure that you will not be the first person to have this problem.
Altenatively go to http://www.luminox.com/service/service-centers/ to find the information on service center locations and contact numbers.
