Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does black slimy film come out of my jacuzzi everytime I use it even though I clean it? and now my drain is clogged
eric vazquez
Level 2:
New Friend:
  • Expert 83 Answers
  • Posted on Nov 21, 2010
eric vazquez
Expert
Level 2:
New Friend:
Answers
83
Questions
0
Helped
29205
Points
180
Black slime come from not using regularly..fill jacuzzi and pour a cup of dishwasher detergent and turn jacuzzi on for a while..
Bmw 325ci ac leaks onto driver's right foot. How do you clean the drains and where are they located. Thanks
There is a drain hose in the base of the ac chamber that drains condensate out under the car. This hose blocks up with gunk from inside the car ( looks like black slimy moss) and the water cannot get away. You will have to disconnect the hose of the chamber and clean both the hose and the fitting back into the chamber.
Why would clothes conditioner not be flushed into machine ?
The siphon tube in the soap dispenser drawer is blocked with either a fungal/bacterial biofilm or with clogged conditioner.
Pull the drawer right pout of the machine as per the user manual to clean it. the cover over the back of the conditioner drawer will flip up if you pull it. The top half has a dead end tube which fits over a tube with an open end. Clean out every last trace of the (very likely) pink or black slimy film, a cotton bud (US=Q-Tip) is useful for cleaning out the upper dead-ended tube.
Reassemble and pop the drawer back in, and then pour water into the conditioner drawer; if you have done the job properly it should just drain out via the siphon as normal.
I hope that my speedy free reply means you'll be up and running again very quickly with your washing machine, please don't forget to take a moment to rate my answer.
1helpful
2answers
Why is the fabric conditioner not draining from the draw?
Bosch Washing Machines fabric conditioner not draining from the draw, This video will show you how to keep your
soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
3helpful
My dishwasher will not drain out completely. there is always some water left on the bottom which becomes smelly and slimy and makes the dishes anything but clean.
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
After cycle is complete my dishwasher doesn't fully drain water.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film(slimy looking substance).
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
2answers
1helpful
Do I have to clean my jacuzzi every day?
Just clean it once a week is fine.
Please rate!
2answers
HP 2600N PRINTS A BLACK LINE VERTICALLY ACROSS THE PAGE (FROM TOP TO BOTTOM) RIGHT IN THE MIDDLE EVERYTIME YOU PRINT SOMETHING . WHAT COULD THIS BE? I HAVE CLEANED EVERY DRUM, THE FILM ETC AND IT KEEPS...
You either have a defective black toner, a bad fuser or transfer belt. From my experence it is usually a bad toner cartridge. After you print a couple of pages, pull the black toner and see if there is anything on the drum. If there is try shaking the toner, sometimes toner does like dirt and clogs up. If you still have problem you will have to try another toner. I know that is not cheep, but I don't know any other way.
My air conditioner
angela,
the slimy pink substance is the product of long usage and is a normal accumulation of dust and dirt.
have a regular cleaning of the unit to prevent another occurrence of the water not draining out. usually every three months depending on the location of the unit.
tnx 4 using fixya,
drcool
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
