Question about KitchenAid Microwave Ovens
I have a KHMC106W Micro-Convect Hood - all of sudden when we used the microwave it didn't sound right and the food never heated up. I unplugged and waited about 2 min and replugged back in and it still didn't work. I tested the convect oven and that worked at least it heated up the food. Do you know what else I should check?
    Sergeant:
  • 225 Answers
The Magnetron has gone (yes it's really called that) that's the part of the microwave that emits radio waves and cooks your food... 30 years ago when this tech (Microwave cooking) was new and expensive it was cheaper to replace that part than buy new... now it's the other way around... at least you still have a working electric convection oven.
it's very rare that a Magnetron go bad, so look for an old one of the same model and use that one for parts if it's that loved.
Posted on Nov 18, 2017
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9176 Answers
SOURCE: microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
MicrowaveSvc
William Miller
  • 9176 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Posted on Sep 06, 2008
Anonymous
SOURCE: Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Posted on Feb 12, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: My microwave oven is not heating the food
HI, you will need to replace the heating device. This device is called the Magnetron and, it will cost you about $133.00. This is a repairable issue but, you will need to call for service. I do not recommend installing this device if you are not familiar with handling this type of tech.
Posted on Jun 01, 2009
A Miller
  • 8404 Answers
SOURCE: microwave sparked out now it does not work
You had something metal inside the microwave. Do you have a rack inside on a revolving tray? On my microwave, if the foot of the wire rack is not on the revolving tray, it will spark against the floor of the oven. Microwave will go around round pieces of metal - it will spark if it finds a flat surface. I dont think you did any damage to your machine but try to not do this again.
I hope this helps you.
Posted on Sep 09, 2009
The microwave is not heating the food.
When it did heat food before and you used the same settings now, the microwave must be defect.
But before you are sure, put a cup with water in the micro and try to heat that.
Dry food can't be heated in a microwave. There must be some moist in the food if you want to heat it in the microwave.
Mar 13, 2015 | Microwave Ovens
Sharp 1200w microwave seems to be tripping lightly (can hear clicking noises)and cause heating to be irregular
Clean the food off the inside top of the microwave Now,Or that noise you are hear will stop along with the microwave. The food gets on the Formica Squire which is how the micro waves heat your food. 1st unplug the Microwave then spray the inside of the unit with something like Fantastic or something strong and use glove so you don't burn you hand,Also if you have a scrub brush use it,And clean all the soap out and raise very well.
May 02, 2012 | Sharp Microwave Ovens
My frigadare microwave runs normal but wont heat the food
From the description you have provided, the magnetron has shorted. This a job for a professional because there is lethal voltages present that will kill.
Mar 27, 2012 | Frigidaire Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Kenmore Elite micro/convect model 64289. Convect not heating...F1 error
F 11 code. it is a touch pad error.
if you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 18, 2010 | Kenmore 63672 Convection/Microwave Oven
My spacemaker just stopped heating food. What do
This is a microwave, correct?
I suspect the door lock interface switch(es) are burned out. Unplug it, be mindful of the 25,000 volts in the silver thing. Check the micro switches (look where the door closes on the top right side, probably) two positions, normally open or normally closed. check them for proper operation.
Micro switches are the most common of microwave failures because most of us open the door while the machine is running causing arc at the switch and burning up the little contacts.
Sep 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Over range microwave, JVM1660
This just happened to ours as well. Apparently the magnetron (device that creates radio waves that heat the food) is broken. I'm trying to pry the darn thing out of our kitchen now so I can replace the magnetron. Look for this part WB27X10489 on Google. I found it on ebay for $65. If it fixes the problem I'll post again.
Aug 18, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
