I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Check your stitch length regulator is not set on zero.
Remove the needleplate and clean out any lint from between teeth of feeddogs......while you are at it, clean around the bobbin area and remove any lint under bobbin case.
It will have something to do with your stitch length regulator.....when you adjust from Zero and watch the feeddogs, you should see them move as the number increases even when not sewing.......I have known many old Singers whose feeddogs move back and forth but do not rise......broken gears the cause, but as to the opposite scenario, without looking at it, very difficult to diagnose.
As to the idea of oiling sewing machines............on these pages are literally litres of stories of machines playing up and folk "oiling" them...........it is NOT a cure all, and a very little occasionally at the junctions of the moving parts (mostly inside the casing and unseen by users) is all that is necessary, ........so proactive rather than reactive.
A regular service by a qualified technician every couple of years (more often if frequently used or quilting) will ident potential problems and keep things moving smoothly.......we all take our cars to be serviced fairly regularly..these machines need the same attention to work well for years.
I had already done an extensive job cleaning lots of lint out of the bobbin area, oiled the machine, but to no avail, the feed dogs still only go up and down not back and forth pulling the fabric through like it should. :-(
Any other suggestion? I suppose I will have to take it to a shop for repairs.
Thanks anyway!
