SOURCE: Picture Problem with Sharp LCD Model LC-42D43U
Hi...there,
It's seems your backlight inverter are busted... Need to replaced a new one.
SOURCE: I have a brand new Sharp LC-42D62U 32" HDTV.
it has a problem with the main board, i would call the place you baught it, they will eather exchange your tv, or tell you to call sharp, at any rete, it is under manufacturers warinty, and everything is covered for a year
SOURCE: sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
SOURCE: Hello, I have a Sharp LC-26DV24U flat panel TV
There was a problem in the power supply section. Check for any loosened components a power transistor or a resistor.
SOURCE: Sharp Aquos LC-37d40u made a
That sounds like a dead power supply. Smell it to see if it stinks like it overheated.
There are 4 13v connector pins that can be spliced into from one standard spliced wall wart.
Common is negative if you study the mobo by scratching off the paint. Both fuse tracks for instance are positive, there are two more positive pins.
