Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher Logo
Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Food gets stuck on dishes especially in the top rack.
Anonymous
Level 2:
  • Expert 128 Answers
  • Posted on Nov 21, 2010
Anonymous
Expert
Level 2:
Answers
128
Questions
0
Helped
164928
Points
316
There is a waste filter in the bottom under the lower spray arm that needs to be cleaned periodically. If you are not cleaning it, it may be redepositing food particles on your dishes.
remove and clean the filter, and see if that helps.
1 Related Answer
Anonymous
  • 128 Answers
  • Posted on Mar 22, 2010
SOURCE: fine grit on dishes
Depending on the machine you have it will have a filtering system to filter out food waste as it washes. This stops the food from being circulated by the wash process as water is cycled through the pump, internal plumbing, and washer arms. Your unit is failing to filter the water.
On the base of your unit in the centre on the floor will be a drain. Some have a visible filter and others have "soft food disposal" system. They are meant to be opened and cleaned from time to time and yours sounds like it is time.
Visible filters will lift out. Some you turn or there will be a catch holding it in place. Others will have obvious screws holding the filer. Open yours and take a look for food waste or debris clogging the drain and filter. Clear out anything you see there.
The washer arms also clog over time. You can remove them also and clear away anything from inside. The holes in the arms can be cleaned with a bamboo skewer or piece of wire. This often makes on old tired machine perform like new again.
While you are in there, check under the float valve. It looks like an upside down tea cup on the floor of the machine usually near the front. Make sure nothing is stuck under it and that it lifts up and down freely.
Hope this helps you. Please rate this answer if it has helped you.
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 • Dishwashers
3helpful
2answers
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
1helpful
Top rack of dishwasher seems to deposit particles of food on to glasses so not only are they dirty at the end of the cycle, the pieces of food particles are difficult to scrub off them. This happens with...
check the holes on the sprayer for the upper rack, somtimes they get pluged up and the top rack dishes wont get sprayed off. if they are pluged remove them and wash in a sink
Oct 26, 2009 • Dishwashers
2helpful
Dishwasher not cleaning dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
I have a kenmore dishwasher and the dishes, especially on the top rack have debris stuck to them after it has run. What should I try?
Remove top spray arm and flush through the holes with running water. Then re-attatch.
It's usually bits of food debris that block the holes.
Aug 04, 2009 • Dishwashers
2helpful
Whirlpool dishwasher. dishes on top rack are not getting clean
Check the center sprayer is not clogged. The two arms should have clear holes and some of the sprayers have a center post that raises to clean the top rack. Make sure the center post lifts by hand and is not stuck with food or gunk.
Apr 30, 2009 • Dishwashers
Food is being shot into the top rack and getting stuck inside the glasses. It is a brand new dishwasher-had it for a week. We have tried different settings on the dishwasher and different detergents
It sounds like you have a great deal of water pressure which a plumber may be able to address.
Otherwise, This may sound simplistic but it may be easier to hand rinse the dishes that have a lot of food still on them before they are placed into the dishwasher.
Good luck. :)
Apr 26, 2009 • Dishwashers
11helpful
2answers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 • Dishwashers
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
