wow first post ever posting country ,what a brave person. !!!!
welcome to USA forums ,that have no such car.(truck)
the line up. (wiki list) so its 3.0L 4JX1
stalls and lost power.
The 4JX1 is a 3.0L direct injection diesel engine, turbo, some intercooled, which replaced the 4JG2 in the
Isuzu Bighorn/Trooper/Holden Jackaroo. It uses unit injectors and 4 valves per cylinder.
can be caused by many reasons. get it scanned yet. ?
or see FSM book on flash codes from the direct injection fuel
controller? (per this engine option and market)
does turbo have proper boost? (PSI boost or +1 bar boost?)
does it even have a boost gauge.?
there are over 50 causes, of stalls (most inside engine)
but its not getting boost or the injection rates are wrong.
there are basic tests for each covered in the FSM
Factory (oem) service manual, with coverage for this engine.
3.2 L
6VD1 SOHC V6
3.2 L
6VD1 DOHC V6
3.5 L
6VE1 DOHC V6
3.0 L 4JX1
TD I4
3.1 L 4JG2 TD I4
I have the same problem with my 1996 2.8L diesel turbo. If I put my foot down on the accelerator, pump it and crank, it does start sometimes. Other times it won't. Any suggestions?
