Question about Electrical Supplies
I put too much carrot skins down the disposal , the blades turn but the water will not drain
You have to take apart the tubular drain pipes located under sink.
It will be fun.
Here's some do-it-yourself information to save calling plumber.
Take apart tubular pipes and clean them out.
Take a photo of the drain before starting. Take other photo as needed for facebook.
Once pipes are apart, run water or use coat hanger to clean out disposal.
Not necessary to take disposal out.
1) Tubular pipes connect to disposal.
Each tubular pipe has a nut and washer.
Pipes can be metal with rubber washer.
Pipes can be plastic with plastic washer.
2) Tubular pipes come apart with channels locks
3) You need a bucket to catch the water when you take apart tubular pipes.
Keep towel handy.
4) All tubular pipes that get moved while working under sink have to be taken apart, cleaned and re-assembled. All you do is take them apart, clean them out, clean them up, and re-assemble the same way they came apart.
5) Take a photo of the drain assembly before starting. Always start with the P-trap shown image above. Loosen top nut and lift up nut. Next, loosen tubular pipe that connects to disposal. and see it can lift out of P-trap without moving any of the other pipes. If clog is inside p-trap, then p-trap will have to come off. Try not to move any other drain pipes; any drain pipe that gets moved will start to leak and needs to be taken apart, cleaned and re-assembled.
6) For best results:
After clog is removed,
Clean all tubular pipes and washers before re-assembly. Take photos as you go so you know where each part goes.
Plastic washers are re-used.
Flat part of plastic washer fits against nut, tapered part away from nut.
Rubber washers can be re-used depending on age >> new rubber washers are best.
7) To re-seal tubular pipes first-time every-time, use rectorseal on rubber or plastic washers.
As you are re-assembling, smear healthy amount over entire washer and then tighten the nut.
Wipe off excess on outside of pipe.
Add a comment if you have a problem.
Posted on Nov 21, 2010
  • 2,591 Answers
Try filling it up with hot water with a little disk soup run it and repeat when it clears fill the sink up with water as high as you can with out spilling over and pull the stopper out do this 2 to 3 times and it will clear the pipes out When you see the whirlpool and hear the sucking noise its clear but you should do this once and a while anyway put a little bleach in first if you think you have problems i live on the 1st fl 1921 3 family house this will work
SOURCE:
Disposal is operating (turning)but not breaking up anything nor is the water draining
if the water drains normally without using the disposal sounds like the blades on the disposal are not working properly. may need to replace the disposal.
Mar 12, 2015 | Dishwashers
Tip
How to unclog a garbage disposal
Before you tackle this problem, you should understand how to use your disposer so you'll probably never have to deal with a clog again. You can easily use put a sinkfull of waste down your disposer without a hitch. It's all about controlling the amount of water mixed in with the waste. Your disposer is designed to break waste down to pieces a little smaller than a BB. This is efficient but without much water, the pieces will clump together right where the disposer connects to the drain line, and will cause a clog. Never turn on the disposer without a full flow of cold water. Cold water not only helps to cool the motor, but keeps any fat solidified so that it doesn't build up on the walls of the pipes. The full flow of water will allow the disposer to mix the waste in and it'll go right down the drain. The second thing you must control is the amount of waste that goes in the disposer. It's really a bad idea to put more than like half a cup of waste in the disposer without it running. Ideally you'd turn on the water first, then start the disposer, then feed the waste in. Listen to the disposer running with waste in it. It sounds different when the waste inside is gone. Use this to get yourself used to keeping up with its pace. The problem with any disposer is that they work so fast, they can grind the waste faster than the water can carry it away.
Whatever you do, don't use a chemical unclogging product. Over time, this can damage the metal components of the disposer, and if you have to call a plumber, they will charge you extra because these chemicals make their equipment wear prematurely and can burn the skin.
If water doesn't drain, make sure the problem isn't fixed by simply turning the disposal on. If the water just swirls around, you'll probably need a plunger. When you want to use a plunger to unclog your disposal, the easiest way is to use suction more than pressure. When you push down on the plunger, the pressure from it will cause the backed-up waste to compress even further and make it impossible to push water down. You want to push the plunger down so that it "leaks" water out, and, when the plunger can be pushed down no farther, make sure it then has a good seal on the disposal's opening, and yank the plunger up pretty hard. This will pull the backed up waste back, mixing it with the water and will probably unclog the unit in only a couple strokes. Be careful not to soak yourself when pulling up on the plunger. In a pinch, a full soda can will actually form a seal and can be used in place of a plunger for disposals that have a splash guard made of one piece. If water is backed up into the other sink bowl, that means the clog is in the trap and not in the disposer itself. One way to fix this is to make sure the other bowl(s) of the sink are firmly stopped up. If you use a stopper you'll most likely have to push down hard on the stopper while plunging the disposer to form a good seal. If none of this helps, you may need to take apart the sink trap. This can be done by loosening the two nuts on the part of the drain pipe assembly shaped like a "U". You then may be able to clean the clog directly out of the u-bend or you may need to snake the pipes. If you take the pipes apart, have a bucket under there to catch the large amount of that will gush out.
on Dec 07, 2009 | Plumbing
I have a brand new garbage disposer and was surprised that it was so quiet. I've been in homes with a disposer and they are noisy and the water and scraps get sucked down the drain quickly, but m
You're complaining that the garbage disposal is working quietly?
Most folks complain the opposite.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Look down opening and see if blade is spinning rapidly.
Check that disposal eats lettuce leaves and carrots.
Otherwise you have good disposal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 21, 2012 | Badger 5 All Insinkerator 76037h 1/2 Hp...
When my dish washer discharge water instead of the water going out the drain it come out the overflow valve.
The dishwasher usually drains into disposal, or directly into tailpiece, and water drains down to the p-trap.
Trap may be clogged or stopped up.
Clean out drain line, tighten connection where dishwasher attaches.
Clean out bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
Oct 18, 2012 | Kohler K-692-7 Clairette Kitchen Sink...
Garbage Disposal Ace 2000 model 47982.... The water won't drain out of it and the sink is backed up and hasn't gone down for a whole day now. It seems like the blades are turning. I've been...
Hi David,
Are the blades actually turning or is just the motor running?
First, turn off the power to the disposal at the circuit breaker. Do not put your hand in until you do this.
If you hear the motor running, but not the blades, then the blades are jammed. On most disposers you can put an allen wrench in an opening under the unit and move the blades. If the blades move freely, then your drain line is probably plugged.
If the motor runs, but the blades don't and they will move freely by hand, then the disposal needs repair.
If the blades are jammed with food, you can clear the jam with your hand and the allen wrench trick from underneath.
Once the disposer is freed up, run cold water down the drain for a few minutes to harden any grease build up inside. Then running the disposer should get rid of the hardened grease.
By the way, most disposers have a reset button on the bottom of the motor should your disposer jam and turn off or trip your breaker.
Orange peels, etc. will not harm your disposer. A good way to keep it clear is to put egg shells down it periodically. The shell action will scrape junk off the inside of the disposer.
You can also keep the disposer clean of grease buildup by pouring some baking soda in the disposer followed by a mix of hot water and vinegar.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator blades don't seem to be cutting, so I keep getting blockages in the U-bend. The motor works fine - how do I change the blades?
To my knowledge the blades are not replacable. Some things do not go down the drain well, potatoes, carrots, mostly vegetable that when mashed will set up. You can clean your blades by putting a few ice cubes down the disposal, don't do too many at a time or the ground ice will plug the screen. If you grind up potatoes or such do just a small amout and run plenty of hot water with it.
Jun 09, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
Used reset button, the motor runs but the blades are not turning?
sound's like you have a problem with your drain pipe's. it is not normal for water to come back up.check the allen key bolt, located on the bottom of unit .insert allen wrench /key,and turn in a clock wise&counter clockwise motion to see if disposal is jammed.you also might consider some drain opener before it get's worse
Apr 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The garbage disposal goes on, but it is not draining. In fact, brown water and carrot peels are coming back up -- a definite clog!
The clog is most likely not right there at the disposal. It's probably further down the drain. If you wait a good long while (an hour or two) before you run the water, then run the water to see how long it takes to back up, you can get an idea of how far along the drain the clog is. Hopefully you have a clean-out port where you need it. A drain snake may be needed.
By the way, a common clogger is to run a bunch of peels through the disposal then not run enough water to chase them all of the way to the larger diameter drain.
Apr 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal won't drain
sounds silly but try loading it with ice and turning it on if there is debris in it the shards of ice will help to clean it
Oct 07, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal blade locked up after finding bone piece
You need to purchase a garbage disposal wrench. It has a Tee at the top and extends down to a pivot with a large forked head. Drop this down and turn the blades until they start to move. Remove the wrench, run hot water and turn on your disposal. Both blades should now be free. There also might be a red reset button on the bottom.
Jul 04, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Electrical Supplies Logo
221 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
