Hi, its seems like the belt on the motor has either slipped or just needs to be tightened more, best way to find out is open the front cover showing the motor, step on the treadmill and see what happens. if the motor is still spinning and the belt isnt then its the belt, check the tension if it is loose just tighten the belt. if the belt and motor are fine then its the running belt that needs to be tightened, to check this just put your hand under the belt and try lifting it, if you can easily lift its 2 0r 3 inches then its ok, but if you can lift it alot more this will need to be tightened, hope i have helped.
