Re: I need an owners manual for my freemotion tt30...
E-mail [email protected] (I found it on the FreeMotion website). I needed one too, and they just send me a response with a pdf file of the manual. Hope that helps!
It sounds like there might be a issue with the control board of your treadmill. The control board is responsible for managing all of the functions of the machine, including the speed of the belt and the operation of the fan. If the fan speed is increasing when you press the up arrow, but the belt speed is not, it suggests that there is a problem with the control board that is preventing it from sending the correct signals to the motor to increase the speed.
To resolve this issue, you may need to have a technician take a look at the control board and repair or replace it if necessary. Before calling for service, you can also try resetting the treadmill by unplugging it from the wall for a few minutes and then plugging it back in. This can sometimes resolve issues with the control board. If the problem persists, I would recommend contacting the manufacturer or a professional repair service for assistance.
please RUN the software calibration for easy diagnostic and fix it. go to HOOD cover motor, and follow the steps, or ready your owner manual God bless you
please test the battery by new ones, clean the contacts batteries and replace . test the reed switch see the diagram attached. However you must download from www. fitness.manualsonline.com
Inmediately LUBE the deck belt, this happen because the lack of maintenance schedule, see your instr. manual and follow the steps. 2) Lube the rollers bearing use the wd-40 see the video attached. God bless you
1) Lube the machine see the video and use the common sense, this happen because the lack of maintenancae according with the instr. manual. Shut down the machine for to protect the electronic system.
2) Lube the rollers bearing too, very well.
3) Test the input voltage motor, if there are the motor NEED repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
