Watches Logo
Anonymous Posted on Nov 20, 2010
Coaster model 900723 grandfather clock doesn't keep time
  • Anonymous Nov 20, 2010
    If you are not familiar with this brand of clock it is a clock that runs on batteries. Not really a true grandfather clock. The pendulum and chimes run on batteries too.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
974
Points
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry.Coaster model 900723 grandfather clock - _1513.jpg
Yvonne
Level 1:
Scholar:
New Friend:
  • Contributor 53 Answers
  • Posted on Mar 28, 2013
Yvonne
Contributor
Level 1:
Scholar:
New Friend:
Answers
53
Questions
0
Helped
29489
Points
61
If this is a mechanical clock with a pendulum, then you can do the following. On the pendulum there is a round bobbin, under the bobbin is a nut, this nut is called a rating nut. To speed the clock up, turn the nut from left to right and to slow it down, right to left. I do not know the length of your pendulum. You need to experiment. Try 1 full turn over 24 hours.
You will probably find a difference in time keeping between Summer and Winter. This cannot be helped. This is called expansion and contraction.
I fix these mechanical clocks for a living so if you need more information you are more than welcome to email me Yvonne [email protected]
  • Yvonne Mar 28, 2013
Tom Carson
Level 3:
  • Master 3,083 Answers
  • Posted on Nov 20, 2010
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
684234
Points
8555
These units have a battery driven clock movement, and so the first thing to check is that the batteries are good, and also that their contacts, as well as the ones in the clock, are clean and free of dust or oxidation.
There is little else you can check, unless you're a watchmaker, and can repair or clean movements. The best thing to do, if all else fails, would be to purchase a new movement. A watch repair shop should be able to get you a replacement movement.
Good luck, and hope this helps.
    Sorry!!! A true clock maker or watch maker will not bother with battery driven clocks. They are not worth the trouble and if they do fix them you will be charged way more than what the clock is worth.
Anonymous
Level 3:
  • Master 10,515 Answers
Anonymous
Master
Level 3:
Answers
10515
Questions
Helped
2935770
Points
31530
Kindly read the below paragraph :-
A grandfather clock cannot work properly unless the weights are adjusted weekly. While the pendulum works off gravity to pull the weights, the weights themselves will begin to get off balance, and the clock will not keep the right time. The owner must adjust them to the proper heights. Each weight has a different height so that the pendulum's swings affect it differently. They move the hands around the clock, based on a certain number of swings from the pendulum. If a weight is set too high or too low, it will cause the corresponding component of the clock to move at the wrong speed, throwing the time off.
There is a nice troubleshooting list :-
http://www.grandfatherclocks.info/grandfatherclockmovements/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
    Taran, Sorry to burst your bubble but you have no cooking clue what you are on about. I suggest you get your facts right. Weights are the driving force of the clock and the pendulum regulates the time. You can email me at [email protected] I fix these clocks for a living!!!!
2answers
Daneker grandfather clock
Yes chiming clocks always have a switch to turn them off. Often termed a 'night shut off'.
https://www.google.com/search?q=daneker+grandfather+clock+turn+off+chimes
Nov 07, 2021 • The Watches
1helpful
W & H clock how to set winding mechanism
Hello, Swannie -
Are you asking about a Winterhalder & Hofmeier clock? If so, what model are you asking about? You can add the model information by choosing Comment and typing the information.
If you do not know the model of the clock, if it is not a tall case (grandfather) clock and you can transport it easily, I suggest you take your clock to a reputable clock repair shop in your area and ask one of the knowledgeable people at the shop about setting the time and winding your clock.
Best wishes.
Apr 02, 2018 • Watches
1helpful
I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
Howard Miller Grandfather Clock
Dec 06, 2016 • The Watches
I purchased a Howard Miller grandfather clock and its keeping time but the pendulum is barely moving. What vould be the problem?
If the clock has a real clockspring mechanism ( with dozens of visible gears), then the problem is likely it needs to be cleaned.and adjusted.
Polaris grandfather clock runs slow need to adjust time up
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Nov 17, 2012 • Watches
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 • Watches
5helpful
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 • Watches
1helpful
Clock cleaning
This is not as easy as you might think. We learn decades to repair (cleaning included) watches and clocks. Any tip would be with no use, as every clock needs individual and specific attention.
The only tip is: visit an eBay and buy the clock repairers book. I've seen some books there.
All this is under the ''Jewellery and Watches'' section.
Mar 27, 2009 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
