Pride Mobility Products Jazzy Select Logo
Posted on Nov 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On the Jazzy select what color for charging indicates fully charged, red, green?
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Nov 21, 2010
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288823
Points
1801
Scraig Lights on the joystick all lit up to the far right and the green light lit on the charger. Red indicates charging or blinking red indicates error in charger. Hope this helps
How can I know when my battery is fully charged?
You have two good batteries in the green side, the red light means that one or both batteries are not fully charging. Try that set on the other side to confirm. Make sure the batteries and charger connections are clean.
Hope this helps.
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Replaced batteries in Jazzy 600 but they will not charge up.
doug then you could have received a bad battery or you have a charger problem or a charger circuit problem. If the chair comes on then the wiring is ok. when you plug the charger in do you have a green light and a yellow light on the charger? (when fully charged the light goes from yellow to green indicating full charge) If when you plug the charger in and you have a red and green light then there is a problem with the charging citcuit. I would contact your provider where you got the chair to have them check it out for you Hope this helps
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
2helpful
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
2answers
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
