Model dvdr3576h/37 digital tuner not working, analogue pass thru working fine. Cannot scan/add/change DTV channnels Digital TV using same antenna cable receiving digital sinals fine.
The Coax from the Antenna is analogue, so that is not going to work. It would have to be Coax to analogue tuner, and to digital if it has a digital out, or if the digital box has an analogue in.
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
You don't say what you are trying to input but take note that your model does not have a digital tuner on the DTV input. If you use a digital OTA antenna, the signal must first go through a digital converter or tuner before it goes into the DTV input. The DTV/ANT input is only cable ready. There is no digital tuner in the TV to activate the DTV menu.
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Hi, Your Tv does indeed have an analog tuner for UHF and VHF reception. Remember you need to have an external antenna connected to receive anything via the analog input. On your remote in the upper right hand corner is a button labeled tv/dtv that will switch back and forth between your analog and freeview digital. Good Luck, this should Fixya!
No, your television has a digital tuner built in. You will not need a converter box. When the switch to digital is made, simply use the auto scan feature to program all of the new channel locations. Instructions found in the manual here - http://www.p4c.philips.com/files/2/26pf5321d_37/26pf5321d_37_dfu_aen.pdf
