You will need to tap into an existing water line. It is reccomended that you use a 3/8" braided tubing. You can get everythin you need from lowes. First you will need to know how far you have to run the hose and what size the existing water line is. You could just tell the people at lowes or home depot or a local hardware store what you need and they can provide you with the proper equipment, usually just a quick connect or barbed tee, hose and clamps. You may have to drill holes through you cabinets and counter. Hope this helps. WWW.MidstateBeverage.com
Below is the master help link
provided to go through belt routing diagram:---Timing belt, drive belt, serpentine
belt, accessory belt, fan belt, engine belt routing diagrams for all types of
car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
ecu with prom chip installed, need further flashing instructions
