Sony CFS-914 Cassette Boombox Logo
Posted on Nov 20, 2010
I only need the amperage for the adapter for a CFS 914 sony radio. Thank you
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 24, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
218
Points
The adapter is an AC-905. The important bit is the 500 mAmp. The actual part number is 169301611
Sony cfs-905 will not run with ac adapter
How can you charge the batteries from your unit if the AC power source cannot works in? Maybe the DC adapter socket's solders was cracked or loosed.
2answers
2helpful
I dont have the manuals to my philips universal remote so i need to add componts dvd
Try this link, http://www.universal-remote.net/philipsmagnavox.html
or instructions are as follows - Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
TV
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
11helpful
Need to know Amps & Volt. for Simpletech "Simple Drive" 1Tb.
The output of your adapter is 12volts 1.5amps the outside terminal is negative polarity and your connector looks like this (see below)
4927b50.jpgThere are two options of adapter (see below) both will work
EBAY Search for your adapter
Bad transformer? Sony CFS-W338 boombox
More than likely there is a voltage resultor in the circuit that will take the 24V input and convert it to 9V internally. This voltage difference is not necesarily a problem. What is the problem with the unit that is causing you to check the voltages?
Dan
1helpful
Sony boombox model cfs-b11 transformer
Your tape requires 9 volt transformer as shown in below schematic..
Part number is 1-450-016-11
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
