Question about Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR
I have a Sterling 1500D shower door, the door has rubbed against the hollow bottom seal and ruined it- I can re adjust the door, I need the part number for the hollow seal kit.
  • Anonymous Mar 19, 2014
    adjusting door anyone
    New Friend:
  • 21 Answers
I think you will find the Sterling 1500D hollow bottom shower seal here. Shower Seals Spares
Posted on Nov 25, 2015
    New Friend:
I have the same problem. I'm doing research today, I'll keep you posted. unless you already figured out where to get the seal, please let me know.
Posted on Feb 01, 2011
SOURCE:
Replace hollow gasket vista-pivot ii shower door
Usually the bottom of most framed doors has a chanel which contain door sweep or hollow gasket,all you have to do is pull it and slide the new one in the same place.
Please note that some times the end of the chanel is crimped to prevent the gasket to move in and out of the track.
I hope this will help.
Nov 30, 2013 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I have a Sterling 1500D Shower door and I need to replace hollow gasket at the bottom of the door. Where do I purchase this from???
It sounds like you need the sweep or seal that keeps water in the enclosure. You can buy these items, which are inexpensive and usually easy to install yourself at www.technologylk.com Technology LK carries a comprehensive range of shower door gaskets, seals and other hardware. If you have any questions about exactly what you need and how to install it, you can contact the company at www.info@technology.com or call them at 888-663-9830.
Jul 10, 2012 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Years ago I purchased a Kinkead Vista-Pivot Shower Door, model 1500-31, Silver. For a variety of reasons the shower didn't get built until recently. However the door opening is now 32.5 inches wide so it...
Ace Hardware sells that door and you will need to see if they can order the parts but it looka like they sell the doors 36" size so when you order you will need to order for the Sterling Plumbing 1500D-36S "Vista Pivot" Shower Door Fits Openings 31 -1/4" To 36" H 66" . Now if you have not completely finished the shower you could always make the door opening fit what you have.
Mar 16, 2011 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Have a sterling 1500D-42S shower door. Need to
sterling is an inexpensive kohler product,....go to a plumbing supply store with your #s and they'll be able to get what you need.
Jan 02, 2010 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
I have istalled a Sterling Pivot Shower door. Everything went well. Except with the door Magnets...They are aligned correctly but are not magnetized..Is there something I can do to magnetize them so that...
this is your mission should you choose to accept it,...one magnet comes out, (usually the door one), what ever one it is, slide it out and put it back in top to bottom-bottom to top, and you'll be all set. let me know if you need more help,......good luck.
Nov 14, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Need to replace drip cap on bottom of door
o.k. these are usually attached with a double sided tape,...you need to get something like a scraper or the like and get in between it and the door,..go slow and pry it off,...SLOWLY! once you get the old one off, you'll need to clean surfaces with a rag and rubbing alcohol,....(very important for new one to stick),.....take your time with this operation,..it doesn't look like much but trust me, i've worked on many shower doors and patience IS your best friend,....again, go slow and pay attention to ALL details.
Sep 28, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Need instructions
Sterling has a video on their website that explained what I needed.
Aug 15, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Installing a stering pivot door
on the pivot side, the seal will go toward the outside,.providing that the seal is on the door,...the seal "on the pivot side of the door" will go up against the wall jamb as you close door,.....
Jun 20, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR Logo
1,209 people viewed this question
Top Sterling Plumbing Home Experts
Donni Steen
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
