Hello shraeder. Go to www.searspartsdirect.com There you will find excellent diagrams and instructions plus the parts. Joe
Thanks for choosing Fixya!
Thank you for contacting Fixya.com. In the model that you have provided the parts are located behind the control panel. Therefore you do not need to remove the oven. Simply open the control panel. Have a nice day.
The part number for the relay board with the transformer is AP2127302. The part number for the relay board without the transformer (lower oven) is AP2127301
Please get back to us if you have any further query.
I have the same issue and understand that i need to replace the upper oven relay board. However, before ordering the part, I took a look at the location of the boards and they are not accessible throught the control panel. The diagram shows them horizontal and adjacent to each other. They are actually located on top of the upper oven and deep to the contral panel. Is the only solution to remove the oven from the wall and remove the top panel of the oven? Very frustrated!
e-Guru, this was a helpful fix. I have the same problem. Need to replace upper oven relay board. However, I can't get to it. I removed the control panel and could see the relay boards, but they are far back and on top of the upper oven. No way to get to them without removing the oven fronm the wall and removing the outer panel as far as I can see. Am I missing something?
Thank you for the information, but how do you access the relay boards?
thanks....that's what I needed to see.
